12748 Discussions
how can i tell the IDE to carry code to TCM
i write a program with assembly instruction,i want this program can be excuted in tightly coupled memory,but when i debug ,this code is not in the TCM,my TCM name is “onchipmemory",my program is follow:
start: nop
call test_code
br start
.section .onchipmemory
test_code:
addi sp,sp,-4
stw ra,0(sp)
movi r2,0x99
movi r3,0xaa
mul r2,r2,r3
ldw ra,o(sp)
addi sp,sp,4
ret
Now,the problem had been solved.Anyway ,thank you for your help.:p
I'm sorry I couldn't help more... How did you solve it?
the code modified as :
.section .instruction_onchipmemory ,"a"
everything is ok.
--- Quote Start ---
everything is ok.
--- Quote End ---
It is very good Idea!
