12748 Discussions
how to Port a LCD to the uClinux
dear hippo
Now I want to port a lcd to nios2, but I meet some problem .
First , i have not understand the frmebuffer in nios . beacuse I have write a hardeware of LCD controller .
[NIOS2]--[SRAM]--[LCD Controller]
[DDR RAM]
that is my structs in my system . so if i want to draw any graph, I only copy the Date of ddr to SRAM . how to create a frumebuffer in NiosII , I wish you can give me a sample . thanks!
Sencod I want to know , how to work the framebuffer. how to get the buffer , i think if I get it ,i can show it.
Now I have find some file in /driver/video
such as SC2410fb.c or .h
how to share the console with Uart
I want to use the Uart and the Virtual Terminal . how to config it in menuconfig
when I select the config
character->[*]Virtual Terminal
[*] Support for consile on virtual terminal
I find I can't receive any information though Uart.
Thanks!
<div class='quotetop'>QUOTE </div>
--- Quote Start ---
  I find I can&#39;t receive any information though Uart.[/b]
--- Quote End ---
maybe you should use console on uart alone during developing the framebuffer driver.
You should check each fb drivers and choose a driver closest to your hardware.
After you have the fb working, you can use microwin ported in uClinux-dist.
