12748 Discussions
how to change page in stand alone lwip web server
how to change page in stand alone lwip web server templete?
I just download stand alone lwip and do a lwip web server templete project.
when I try to modify the page in the fs.zip file,rebuile the project and run on the board,the page in the board dosen't change.
How could I do ?
Thanks!!
The example shipped with stand alone LWIP uses static C arrays to emulate a "filesystem". There's a Perl script, included, that should enable you to turn any directory of files into fsdata.c and fsdata.h.
Cheers,
- slacker
I read the README file in the project.And I also saw a perl script which name is makefadata.My question is that do I have to copy the file makefadata and pages in a unix system for conversion??Or it will automatically convert when I build the project?
You'll have to run the script, yourself. What you'd like to do is not built into the IDE...
- slacker
--- Quote Start ---
i just download stand alone lwip and do a lwip web server templete project.
when i try to modify the page in the fs.zip file,rebuile the project and run on the board,the page in the board dosen't change.
how could i do ?
thanks!!
--- Quote End ---
You're quite correct just change the contents of the zip file, ensuring it's not compressed. The step you're missing is that you need to run the flash programmer, which will actually program the file into the flash.
I'm afraid slackers posts are misleading and referring to Nios 1.0, which did things a different way.
No, I believe the post is asking about "Stand Alone" LWIP, not the uC/OS-II & LWIP version shipped with the kits.
If you're asking about Stand Alone LWIP, follow my instructions. If you're asking about the version shipped with the FULL software, from Altera, then follow rugbybloke's suggestions.
Cheers,
- slacker
I have been succufully do the work.Both stand alone & webserver.Thnak you very much !!
stand alone is use ram file system so we need the perl script to covert the page into .c
webserver is use zip file so we have to flash it with flash programmer.
I am so happy that I success !!
thanks a lot.
