12620 Discussions
how to change the file:/romfs/etc/rc ???
I want to change the file :uClinux-dist-test/romfs/etc/rc and after uclinux booting , I want uclinux automate to run the command which I want to add . Everytime I change this file ,but after make menuconfig, make, make linux image ..(no make clean operation) , it automate to change original file. How to chang it and let it do not chang after make ...
THX
--- Quote Start ---
originally posted by andylei@Aug 19 2006, 11:16 PM
i want to change the file :uclinux-dist-test/romfs/etc/rc and  after uclinux booting  , i want uclinux automate to run the command which i want to add . everytime i change this file ,but  after  make menuconfig, make, make linux image ..(no make clean operation) , it automate to change original file. how to chang it and let it do not chang after make ...
        thx
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=17716)
--- quote end ---
--- Quote End ---
You need to change uClinux-dist-test/vendors/Altera/niosnommu/rc file.
<div class='quotetop'>QUOTE </div>
--- Quote Start ---
You need to change uClinux-dist-test/vendors/Altera/niosnommu/rc file.[/b]
--- Quote End ---
it is OK THX albertyong88! http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/smile.gif
