12748 Discussions
how to create a linux system on a nios2-mmu for a custom fpga board?
I have a custom FPGA dev board, based on ep3c25, with a 16MBytes SDRAM.
I want to build a linux system with mmu support, I have followed the very how to article: http://nioswiki.com/linux, but always failed.(a custom_fpga.h created) The result is:nios2-download -g images/zimage.initramfs.gz; nios2-terminal
using cable "usb-blaster [usb 5-1.1]", device 1, instance 0x00
pausing target processor: ok
initializing cpu cache (if present)
ok
downloaded 1643kb in 14.5s (113.3kb/s)
verified ok
starting processor at address 0xc1500000
nios2-terminal: connected to hardware target using jtag uart on cable
nios2-terminal: "usb-blaster [usb 5-1.1]", device 1, instance 0
nios2-terminal: (use the ide stop button or ctrl-c to terminate)
uncompressing linux...
error
bad gzip magic numbers
-- system halted
Some file(screenshot) attached, please help me. Thank you!!!
(http://www.alteraforum.com/forum/attachment.php?attachmentid=2581&stc=1&d=1275320625)
What is your pc linux distro?
Please set "boot link offset" to 0xa00000 in kernel config. It is about 2/3 of 16MB.
Or, please run nios2-download -g images/linux.initramfs.gz
Or, please try u-boot first to verify your system.
http://nioswiki.com/dasuboot
- Hippo
--- Quote Start ---
- Hippo
--- Quote End ---
Hi, Hippo
Thank you!
My linux distro is Debian(testing).
I have corrected the boot link to 0xa00000 which point to the kernel space. But after compiling:
Using cable "USB-Blaster [USB 6-1.1]", device 1, instance 0x00
Processor is already paused
Initializing CPU cache (if present)
OK
Downloaded 1642KB in 14.3s (114.8KB/s)
Verified OK
Starting processor at address 0xC1A00000
nios2-terminal: connected to hardware target using JTAG UART on cable
nios2-terminal: "USB-Blaster [USB 6-1.1]", device 1, instance 0
nios2-terminal: (Use the IDE stop button or Ctrl-C to terminate)
Uncompressing Linux...
no more character then...
And If I run:
nios2-download -g images/linux.initramfs.gz; nios2-terminal
OK
Downloaded 2638KB in 23.0s (114.6KB/s)
Verified OK
Starting processor at address 0xC1000000
Early printk initialized
No more character then....
Which options should I check next?
Thank you !!
Please rename jtag_uart_0 to jtag_uart in your sopc builder.
- Hippo
