12748 Discussions
how to create a user interface using nios ii , rs232 of DE2 board
hello , i'm working on a student project using the nios ii processor and i need to build a user interface in a PC . i have the DE2 board. i'm a beginner with the nios ii and i really don't know to interface the DE2 board to a PC , how to program the data transmission to get data out at the PC side ? and how to create the user interface , what is the software that i have to use for this ?:confused::confused::confused:
all that i know that i can use the RS232 module in SOPC but how to use it and program it in assembly :(.
i really need your help... thank you
--- Quote Start ---
--- Quote End ---
Why assembly? Almost everyone uses C. Nios dev tools provide the driver for the rs232 module with the basic functions to send/receive data.
Browse the forum and Altera website: you'll find a lot of code samples.
On the PC side the simplest solution is using Hyperterminal or a similar program to send commands and receive answers with a ASCII protocol.
If you need something more complex, like file transfer, you must write a specific client program which manages serial port data according to your needs.
assembly because i'm really used to it more than the c language and actually i'm writing my programs in assembly.
for the hyperterminal; i don't know if we can access it using windows vista ??? i didn't find it :(
I mentioned Hyperterminal because this is what is available on Windows systems. You can use any program which can send and receive data to and from the serial port.
As I said above, you can even write your own terminal program: if you have minimal programming experience, you can write a simple one in less than a hour.
thank u very much Cris72 for ur answer :)
my first problem now is how to use the rs232 interface of the DE2 board to send data to the pc , is it sufficiant to instantiate it in the sopc then program it or shall i download an ip module from the internet ? and how to program the interface ?
i really need any help
thank u
You only have to add the uart module in sopc builder, then you program it like a standard uart controller, by writing and reading its registers.
You don't need to download anything: the core is included in sopc standard peripherals.
Although you are probably better of using 'putty' instead of 'hyperterminal'
thank u very much Cris72 and dsl for ur answers .......is this putty equivalent to hyperterminal ? is delphi suitable to implement the user interface from the pc side ? and one more request ..:oops: does anyone have a sample code to program the rs232 uart using nios ii assembly ( preferable) or C languages
thank u very much for ur help :)
Hi univers,
Yes, putty is equivalent to hyperterminal or to any other terminal emulator.
I don't know Delphi but I think you can certainly use it to implement pc side application, like any other programming language.
If you search in the forum you find some examples of C code for uart management.
thank u very much Cris72 for ur help i'll try to find a sample code here in the forum ;)
