12748 Discussions
how to download the FPGA configuration data in to
hi ,everybody.there is a CFI(common flash interface)flash on my board ,but i only use it to store my software data! how to download the FPGA configuration data in to the flash?
thanks !
with my regard!
NiosII IDE is integrated with a tool name: Flash Programmer.
You can use it to download software or FPGA configuration file.
The menu locates at:
Tools->Flash Programmer
FYI.
regards,
David
i know! but when i download the fpga configuration data to the flash it shows "The target board must define at least one hardware image to program an FPGA configuration."! what shall i do ?
thanks! with my regard!
Hi wbqyy,
Before using flash programmer, you should create a board description for your board so that Flash programmer can identify your Flash device. This function is discussed in QuartusII 5.0 handbook.
As I know, NiosII 5.1 and QuartusII 5.1 will support this functionality without board description. Try it.
FYI
regards,
David
my system could identify the flash ! I also could download the software data into the flash, only when i download the fpga configuration data to the flash, it shows " The target board must define at least one hardware image to program an FPGA configuration." what was wrong ??
with my regards!
Hi, wbqyy
Sorry I can't help more...
I always use Altera's kits, so...
I think this feature must be declared in QuartusII 5.1 hankbook...
If you have any resolution, pls also let me know!:)
Altera's chinese FAE tell me that NiosII 5.1 and QuartusII 5.1 will support this functionality without board description. Try it.
regards,
David
to download ur hardware fpga config code... u hav to use the e command to erase the hardware section (user portion of flash).. then use r command to relocate the stack pointer to the starting of the hardware section, then
nr -p <com port> XXX.hexout
u will now prog ur fpga hardware config to ur hardawre section of the flash memory
i&#39;m just guesing here ,
but try to hopen your target board design with sopc
go to the : "more board system setting tab "
check if in the :" board system setting " section , there should be at least one hw- image defined
I have the same exact problem with the new and improved flash programmer. You are supposed to be able to just create a board description and only need to designate the flash devices in the "Flash Memory" tab. After this, the programmer is supposed to work!! http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/dry.gif
Not only does the programmer NOT work, but once I made a board description, my SOPC system no longer compiles! http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/mad.gif
The Flash Programmer GUI gives the error message:
" the target board must define at least one hardware image to program an fpga configuration."
As for the post by Ilan - I don&#39;t have any tab anywhere called "more board system setting tab".
I also tried doing everything from the SDK shell where I had some success programming - but the verify fails!
The option "more board system setting tab "
Is available only in the target board (this is not the design board)
Read this doc about ug_nios2_flash_programmer.pdf
TO_BE_DONE
You could use the nios2-flash-programmer from the command line rather then the IDE. The flash programmer user guide has more details. You can program from the command line without a target board configured.
--dalon
--- Quote Start ---
originally posted by dalon@Jan 16 2006, 11:42 AM
you could use the nios2-flash-programmer from the command line rather then the ide.  the flash programmer user guide has more details.  you can program from the command line without a target board configured.
--dalon
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=12225)
--- quote end ---
--- Quote End ---
Yep - I&#39;ve tried the command line method and it "seems" to work, although at the end the Verify fails - and sure enough if I dump the memory using a third party tool (FS2) the memory contents compared to the SREC file are incorrect. about half of the bytes are wrong. It almost seems like timing, but I can R/W to flash memory manually using the FS2 command line interface to Nios...
<div class='quotetop'>QUOTE </div>
--- Quote Start ---
The current flash programmer user guide only shows how to make a target board using the Board Description Editor - not the old mk_target_board utility.  I&#39;m sorry but I have no idea where you&#39;re going with that.[/b]
--- Quote End ---
look at ug_nios2_flash_programmer.pdf
the chapter : porting the nios II to custom boards
you will see at page 2-7 step 15 that it do reffer to old mk_target_board utility.
after you will use this utility a target board design will be created that you could open using the sopc. if you will open it you will find there the "more board system setting " tab
figure 2-5 of ug_nios2_flash_programmer.pdf shows a picture of that screen with this tab
i am confused! what&#39;s vision of the "user guide"you discussed?
there is NOT any words about "mk_target_board" in my Flash programmer user guide! oh .....
it&#39;s been so long since I posted on this issue and since then I have had resolution. As it turned out the Altera provided CPLD "configuration controller" does not release the flash I/O pins to tri-state when it is done configuring the FPGA. This was the first problem and so I added TRI&#39;s to the outputs. But, I had forgotten to make pin assignments for a USB controller chip&#39;s control lines that are on the same avalon tri state bus. So, the Nios during flash programming was contending with the USB controller (who was supposed to be quiet on the bus).
Alas, the flash programmer has been working fine ever since then, but NOTE THAT THE VERIFY ALWAYS FAILS EVEN THOUGH DOING A READBACK OF FLASH PROVES THE FLASH CONTENTS ARE 100% CORRECT. No clue why the verify fails - we just ignore it.
