I'm a beginer of nios ii IDE tools,I install the nios ii IDE 9.1 sp1 tool.But when I started to to as the books say,some problems occured.It seems to be a big difference between 9.1 Editon and 8.1 Edtion.I successfully generate the sopc system and also build the C program with no problem ,then, I just can't find the way to download program to the hardware.Anyone help me?:confused:
Hi dqzjh0319.
Please try the following steps: 1. Connect the usb-blaster on jtag mode. 2. Run>>Run Configurations, then create a new configuration, refresh connections in the "Target Connections" table. Click "run" button if it's active.- Mark as New
Thanks for your reply! But I can't find the "run as Nios II Hardware"opinion.For urgent using,I have already changed into 8.1 edition.
