12748 Discussions
how to get the file "nios2-linux-gnu"
Dear all
I porting some software .
for example for ARM
./configure --prefix=/home/nick/minigui/tmp/
--host=arm-linux
--target=arm-linux
I try to do it use next
--host=nios2-linux
--target=nios2--linux
or
--host=nios2-linux-uclibc
--target=nios2--linux-uclibc
but it is fail . I find we can't find nios2-linux-gnu or nios2-linux-uclibc-gnu
can you help me ! thanks!
<div class='quotetop'>QUOTE (Alex.liu @ Jul 31 2009, 08:26 PM) <{post_snapback}> (index.php?act=findpost&pid=23361)</div>
--- Quote Start ---
for example for ARM
but it is fail . I find we can&#39;t find nios2-linux-gnu or nios2-linux-uclibc-gnu
can you help me ! thanks![/b]
--- Quote End ---
That&#39;s just part of porting to an unsupported architecture in an "autotools/autoconfig" based example. You&#39;re responsible for either modifying the configure.in (or something like that) or, if you&#39;re lucky...just adding the appropriate architecture/toolchain stuff in config.sub (config.sub.in).
Initially, you might be able to get it to work just hacking the "configure" script, but you ought to be modifying the ".in" scripts...eventually.
Cheers,
- slacker
