公告
12748 讨论
how to know the tcp socket client broken in nichestack/ucos 2
名誉分销商 II
1,245 次查看
how to know the tcp socket client broken in nichestack/ucos 2,
I want to accept the server socket again after the tcp socket client is broken.
my project is :
I make a tcp socket server for sending data to tcp client only. when the tcp
client is broken (normally, whatever), or so when the client connect again,
the link is not work. I think is: the tcp server task is not quite the while(1) loop,
and not accept again ! or other problem? thanks for your help.
my code just like following:
tcpserversocketTask()
//define local variable
socket(AF_INET,SOCKET_STREAM,0);
bind();
listen();
accept();
while(1)
read a flag from a ram ,when the condition(flag) is true
send some data to tcp client.
TK_SLEEP(1);
0 项奖励
1 回复
名誉分销商 II
503 次查看
have you found any solution?
0 项奖励
回复
