I have some code that works only the first time. See here belowint alt_main(void)
char p="InitText";
while(1)
alt_printf("\nread trough jtag_uart_read");
altera_avalon_jtag_uart_read(JTAG_UART_0_BASE, &p,3,O_RDWR |O_NONBLOCK) ;
alt_printf("\np=%s", p);
return 0;
Current code above reads only the first time a character into the string p[20]. Question 1: How do I change this so that it reads every time the new character? Question 2: How do I read with altera_avalon_jtag_uart_read the registers of the JTAG UART Core? This JTAG UART Core Register Map is defined as: +-------------------------------------------------------------------------------------+
|Offset | Register | | Bit Description |
| | Name | R/W |31 ... 16| 15 | 14 ... 11| 10 09 08 |07 ...... 02| 01 |00 |
| 0 | data | RW | RAVAIL |RVALID |Reserved | Reserved | DATA |
| 1 | control | RW | WSPACE |Reserved | AC WI RI | Reserved |WE|RE|
I can access it with IORD For example: i = IORD(JTAG_UART_0_BASE, ALTERA_AVALON_JTAG_UART_DATA_REG); But it's recommended to use altera_avalon_jtag_uart_read. So is the following possible?
int main (void)
alt_u32 data;
alt_u32 ravail;
alt_u32 wspace;
// read the data into var data (do some '& and | processing afterwards to filter the 8bits out
altera_avalon_jtag_uart_read (JTAG_UART_0_BASE, &data, 1, O_RDWR |O_NONBLOCK) ;
// read the read available into var ravail (do some '& and | processing afterwards to get the right bit)
altera_avalon_jtag_uart_read (JTAG_UART_0_BASE, &ravail, 1, O_RDWR |O_NONBLOCK) ;
// read the write space into var wspace (do some '& and | processing after wards to filter the 16bits out)
altera_avalon_jtag_uart_read (JTAG_UART_0_BASE+1, &wspace, 1, O_RDWR |O_NONBLOCK) ;
return 0;
Rgds, Kimberley
