12748 Discussions
how towrite makefile for driver?
hello friend
i am using nios IDE.i have written module.c and makefile like
CODE:
ifneq ($(KERNELRELEASE),)# kbuild part of makefile
obj-m := module.o
else# Normal Makefile
ARCH := nios2nommu
CROSS_COMPILE := nios2-elf-
KERNEL_PLUGIN:= /cygdrive/d/TOOLS/altera/kits/nios2/bin/eclipse/plugins/com.microtronix.nios2linux.kernel_1.4.0
KERNELDIR := $(KERNEL_PLUGIN)/linux-2.6.x
BUILDDIR := /cygdrive/d/TOOLS/altera/kits/nios2/bin/eclipse/workspace/jay_07_07/build/include
all::
$(MAKE) -C $(KERNELDIR) M=`pwd` O=$(BUILDDIR) modules
endif
and i copy module.c and makefile in my linux application project.
but when i build it then i get following messege on ide console..
make -k all
make -C /cygdrive/d/TOOLS/altera/kits/nios2/bin/eclipse/plugins/com.microtronix.nios2linux.kernel_1.4.0/linux-2.6.x M=`pwd` O=/cygdrive/d/TOOLS/altera/kits/nios2/bin/eclipse/workspace/jay_07_07/build/include modules
make[1]: Entering directory `/cygdrive/d/TOOLS/altera/kits/nios2/bin/eclipse/plugins/com.microtronix.nios2linux.kernel_1.4.0/linux-2.6.x'
/cygdrive/d/TOOLS/altera/kits/nios2/bin/eclipse/plugins/com.microtronix.nios2linux.kernel_1.4.0/linux-2.6.x/Makefile:486: .config: No such file or directory
/cygdrive/d/TOOLS/altera/kits/nios2/bin/eclipse/plugins/com.microtronix.nios2linux.kernel_1.4.0/linux-2.6.x/Makefile:531: /cygdrive/d/TOOLS/altera/kits/nios2/bin/eclipse/plugins/com.microtronix.nios2linux.kernel_1.4.0/linux-2.6.x/arch/i386/Makefile: No such file or directory
gcc: not found
gcc: not found
make[2]: *** No rule to make target `/cygdrive/d/TOOLS/altera/kits/nios2/bin/eclipse/plugins/com.microtronix.nios2linux.kernel_1.4.0/linux-2.6.x/arch/i386/Makefile'.
make[2]: Failed to remake makefile `/cygdrive/d/TOOLS/altera/kits/nios2/bin/eclipse/plugins/com.microtronix.nios2linux.kernel_1.4.0/linux-2.6.x/arch/i386/Makefile'.
CC [M] /cygdrive/e/working_file/test_07_07/module.o
gcc: not found
make[3]: *** [/cygdrive/e/working_file/test_07_07/module.o] Error 127
make[3]: Target `__build' not remade because of errors.
make[2]: *** [_module_/cygdrive/e/working_file/test_07_07] Error 2
make[2]: Target `modules' not remade because of errors.
make[1]: *** [modules] Error 2
make[1]: Leaving directory `/cygdrive/d/TOOLS/altera/kits/nios2/bin/eclipse/plugins/com.microtronix.nios2linux.kernel_1.4.0/linux-2.6.x'
make: *** [all] Error 2
please help me what i have to next..
--- Quote Start ---
originally posted by helmchen@Jul 7 2006, 08:02 PM
well look in the forum
http://forum.niosforum.com/forum/index.php...wtopic=2655&hl= (http://forum.niosforum.com/forum/index.php?showtopic=2655&hl=
http://forum.niosforum.com/forum/index.php...wtopic=2411&hl= (http://forum.niosforum.com/forum/index.php?showtopic=2411&hl=
this has already been done by a lot people.
good luck
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=16713)
--- quote end ---
--- Quote End ---
hi helmchen
i have folowed your given lonk.and i got module.ko.
then i have include module.ko in filesystem-romfs(/home) then using nios ide ,i have generated romfs.bin.
i have load romfs and kernel on my board,but when i try to instole module it is
not allowing to it,it is giving following mess.
none) login: nios2
nios2
Password: uClinux
# cd /bin
cd /bin # ls
ls
agetty busybox cat echo expand init kill login
ls mount ps pwd sh sync umount # cd ..
cd ..# cd home
cd home# ls
ls
ftp module.ko # busybox insmode module.ko
insmode: applet not found#
where am i wrong? please help me .
Nice to see that you were sucessfull.
try insmod instead of insmode.
In addition i would propose to make a ftp connection to transfer your files (programs and module) on your board. It is much easier than to include the new file to your filesystem and upload to your board again and again and again and again... :-).
nfs would work, too.
