12748 Discussions
howto build a openssl Version 0.9.8d
Hello everyone:
I try to build a new version of openssl 0.9.8d with the target build_libs.
The Makefile comes to an end without error messages.
Therefor i add in the Configure file the following line:
"altera","nios2-linux-uclibc-gcc:-O3 -fno-pic -Wall -DTERMIO -DBN_STRICT -DPURIFY -DL_ENDIAN -D_FILE_OFFSET_BITS=32 -mhw-mul::-D_REENTRANT:::BN_LLONG ::http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/smile.gif ",
I use nios2-linux-uclibc-gcc version 3.4.6.
Using my own libssl/libcrypto my system crashes with BAD-MAC error
and enryption is very slow
Using the libcrypto from "hippo" everything is ok. (nios2libs.tar.bz2)
But this is an old Version.
Who to compile/configure a new openssl?
Which flags are needed?
Can someone help me?
I built the old version with buildroot.
You may look at the makefiles in buildroot/package/openssl .
I remove the thing about shared objects.
It should be possible to change them to newer verion.
