Ankündigungen
i have a problem about pio
Geehrter Beitragender II
1.708Aufrufe
i have a problem with pio.
void main
unsigned long M=0;
unsigned long N=0;
unsigned long fenzi=0;
unsigned long fenmu=0;
unsigned long em;
M=6997*4*188;
N=7314*204*8*10;
fenzi=M;
fenmu=N;
while(N > 0)
em = M % N;
M = N;
N = em;
fenzi=fenzi/M;
fenmu=fenmu/M;
after i have computer out fenzi and fenmu,i want to trans them to a FPGA module.
the module have three input port (clk,[31:0] fenzi,[31:0] femu).
what should i do ?
may i use 2 pio port?
if so,what is the code?
3 Antworten
861Aufrufe
HI, snow
are u from P.R.C? http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/biggrin.gif
fenzi? fenmu? http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/biggrin.gif
they are called "arenumerator" and "denominator" in English http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/tongue.gif
i know what u mean. and i suggest u can read "Altera Embedded Peripherals Handbook" section 11 "PIO Core with Avalon Interface" and "Nios II Software Developer’s Handbook" section 4 "Developing Programs using the HAL"
good luck
http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/cool.gif
861Aufrufe
hi oceanx
thank you for your help.
yes, you are right,i am from P.R.C. http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/biggrin.gif
i have read the releated parts of the handbook,and i have try to use it as follows,
# include "excalibur.h"
# include "stdio.h"
# define clk 57600 //73140# define v 7# define outrate 6840
unsigned int Gcd(unsigned int M,unsigned int N)
unsigned int Rem;
while(N > 0)
Rem = M % N;
M = N;
N = Rem;
return M;
void main(void)
unsigned int wnfenzi,wnfenmu,gcd;
unsigned int rnfenzi,rnfenmu,rnzheng;
unsigned int fenzi,fenmu,faqam,qamfenzi,qamfenmu;
unsigned int inqam;
unsigned int bo,co;
//&#35745;&#31639;&#20889;&#26102;&#38047;&#21442;&#25968;
wnfenzi=outrate*v*188;
wnfenmu=clk*204*8;
gcd=Gcd(wnfenzi,wnfenmu);
wnfenzi=wnfenzi/gcd;
wnfenmu=wnfenmu/gcd;
printf("wnfenzi=%d,wnfenmu=%d\n",wnfenzi,wnfenmu);
na_wnfenzi_pio->np_piodirection=0xffffffff;
na_wnfenmu_pio->np_piodirection=0xffffffff;
na_wnfenzi_pio->np_piodata=wnfenzi;
na_wnfenmu_pio->np_piodata=wnfenmu;
//&#35745;&#31639;&#35835;&#20351;&#33021;&#21442;&#25968;
rnfenzi=wnfenmu*47;
rnfenmu=wnfenzi*2;
if(rnfenzi>rnfenmu)
rnzheng=rnfenzi/rnfenmu;
rnfenzi=rnfenzi-rnfenmu*rnzheng;
if(rnfenzi==0)
rnfenmu=2;
rnfenmu=rnfenmu-1;
rnfenzi=rnzheng+rnfenzi;
//&#36755;&#20986;&#20026;rnfenmu(factor),rnzheng(conl_1),rnfenzi(conl_2)
printf("rnfenzi=%d,rnzheng=%d,rnfenmu=%d\n",rnfenzi,rnzheng,rnfenmu);
na_rnfenmu_pio->np_piodirection=0xffffffff;
na_rnzheng_pio->np_piodirection=0xffffffff;
na_rnfenzi_pio->np_piodirection=0xffffffff;
na_rnfenmu_pio->np_piodata=rnfenmu;
na_rnzheng_pio->np_piodata=rnzheng;
na_rnfenzi_pio->np_piodata=rnfenzi;
//&#35745;&#31639;&#36870;&#36895;&#29575;&#21305;&#37197;
faqam=outrate%1000;
inqam=outrate/1000;
if(faqam==0)
fenzi=outrate;
fenmu=clk;
gcd=Gcd(faqam,1000);
qamfenzi=faqam/gcd;
qamfenmu=1000/gcd;
fenzi=inqam*qamfenmu+qamfenzi;
fenmu=clk*qamfenmu;
printf("fenzi=%d,fenmu=%d\n",fenzi,fenmu);
na_fenzi_pio->np_piodirection=0xffffffff;
na_fenmu_pio->np_piodirection=0xffffffff;
na_fenzi_pio->np_piodata=10;
co=na_fenzi_pio->np_piodata;
na_fenmu_pio->np_piodata=fenmu;
bo=na_fenmu_pio->np_piodata;
but when i use modelsim to check the result ,i do not understand the waves.
i mean when the data are written to the pio&#39;s data register,will the pio&#39;s output be always the data? what should i do if i want to output them at a time ,after all the numbers be computed out?
861Aufrufe
HI snow
I suggest u can open the "altera_avalon_pio_regs.h" and "system.h" of NIOS2 project in the IDE and read it carefully.
use these followed macro:
IORD_ALTERA_AVALON_PIO_DATA(base)
IOWR_ALTERA_AVALON_PIO_DATA(base, data)
Reading the English Datasheet carefully before u program http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/smile.gif
Antworten
