impossible boot uclinux
I work on CentOS 5.5. I have followed step by step the examlpes on the wiki community for uclinux. I have correctely dowloaded and booted the image of the example TryOutuClinux. I have tried to built a new kernel image with the ptf file of the same hardware project following exactly the procedure described in InstallNios2Linux, no errors occured, so i downloaded the image. But when i lunch the nios2-terminal, in the nios shell, it is impossible boot linux because the message: "Uncompressing Linux... Ok, booting the kernel." happears but after nothing else.
Everyone know what happens?
Thank you a lot for yours help.
solved uninstalling my the toolchain and using prebuild binary toolchain.Now i can boot uclinux using my image.
Someone has ideas why using my toolchain i could not make the boot? I have built my toulchain without errors, but using this it doen't work, it works only with prebuilt binary toolchain. Why?
