interrupt in button_pio
HI,
Does anyone know how to get button_pio to run a function based on interrupt.
E.g. Press a button, it generates an interrupt so that cpu can read the status and do something.
I am currently using polling which is a waste of cpu resources.
Any pointers or code that would help. Thanks.
\com.microtronix.nios2linux.kernel_1.4.0\linux-2.6.x\drivers\char\altera_pio_button.c
you can find a lot about pio buttons in the forum.
I have looked at the example as suggested, but just couldn't understand it.
It looks like it's a driver.
I am just trying to write an application is based on pio interrupt. Anyone has some simple example application that allow me to that ?
You cannot use interrupts under uClinux in a userapplication. Interrupts can only handled in kernel drivers.
--- Quote Start ---
originally posted by albertyong88@Nov 15 2006, 05:14 PM
hi,
i have looked at the example as suggested, but just couldn't understand it.
it looks like it's a driver.
i am just trying to write an application is based on pio interrupt. anyone has some simple example application that allow me to that ?
thanks.
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=19440)
--- quote end ---
--- Quote End ---
You need to read the book "linux device driver 3rd ed" .
seperate device driver from your application improve your program.
What I have done now is included the altera_pio_button.c into the source tree locally, and change Makefile and Kconfig accordingly, and then compile by doing
make; make linux image;
All seems to be fine, but when I look at /proc/interrupts, there is no list of pio_buttons nor is there /dev/btn
Any ideas what went wrong ?
--- Quote Start ---
originally posted by albertyong88@Nov 15 2006, 11:44 PM
hi,
what i have done now is included the altera_pio_button.c into the source tree locally, and change makefile and kconfig accordingly, and then compile by doing
all seems to be fine, but when i look at /proc/interrupts, there is no list of pio_buttons nor is there /dev/btn
any ideas what went wrong ?
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=19452)
--- quote end ---
--- Quote End ---
you need to open and read the char dev /dev/btn.
eg, cat /dev/btn
The nios2 patches (ver17) to uClinux-dist are updated to include button and lcd drivers now.
Sorry, did this twice.
Hi Hippo,
I got the new kernel patches, and included in my new built.
However, it booted up, there was nothing indicating the driver is loaded.
I am attaching the boot screen
<div class='quotetop'>QUOTE </div>
--- Quote Start ---
Uncompressing Linux... Ok, booting the kernel.
Linux version 2.6.17-uc1 (uclinux@colinux) (gcc version 3.4.6)# 29 PREEMPT Tue N
ov 21 10:20:08 EST 2006
uClinux/Nios II
Altera Nios II support © 2004 Microtronix Datacom Ltd.
Built 1 zonelists
Kernel command line:
PID hash table entries: 256 (order: 8, 1024 bytes)
Dentry cache hash table entries: 4096 (order: 2, 16384 bytes)
Inode-cache hash table entries: 2048 (order: 1, 8192 bytes)
Memory available: 30312k/32768k RAM, 0k/0k ROM (1475k kernel code, 663k data)
Mount-cache hash table entries: 512
NET: Registered protocol family 16
NET: Registered protocol family 2
IP route cache hash table entries: 1024 (order: 0, 4096 bytes)
TCP established hash table entries: 1024 (order: 0, 4096 bytes)
TCP bind hash table entries: 1024 (order: 0, 4096 bytes)
TCP: Hash tables configured (established 1024 bind 1024)
TCP reno registered
io scheduler noop registered
io scheduler deadline registered (default)
You have init Device 250
Serial: JTAG UART driver $Revision: 1.1 $
ttyJ0 at MMIO 0x822208b0 (irq = 1) is a jtag_uart
smc91x.c: v1.1, sep 22 2004 by Nicolas Pitre <nico@cam.org
eth0: SMC91C11xFD (rev 1) at 82210300 IRQ 6 [nowait]
eth0: Ethernet addr: 00:07:ed:0f:06:92
i2c /dev entries driver
i2c-oc: i2c Opencores adapter driver
Opencores i2c algorithm module
TCP bic registered
NET: Registered protocol family 17
Freeing unused kernel memory: 532k freed (0x4182000 - 0x4206000)
Shell invoked to run file: /etc/rc
Command: hostname uClinux
Command: mount -t proc proc /proc
Command: mount -t sysfs sysfs /sys
Command: mount -t usbfs none /proc/bus/usb
mount: Mounting none on /proc/bus/usb failed: No such file or directory
Command: mkdir /var/tmp
Command: mkdir /var/log
Command: mkdir /var/run
Command: mkdir /var/lock
Command: mkdir /var/empty
Command: ifconfig lo 127.0.0.1
Command: route add -net 127.0.0.0 netmask 255.0.0.0 lo
Command: ifconfig eth0 192.168.50.63eth0: link down
Command: cat /etc/motd
Welcome to
          ____ _  _
        /  __| ||_|
    _  _| |  | | _ ____  _  _  _  _
  | | | | |  | || |  _ \| | | |\ \/ /
  | |_| | |__| || | | | | |_| |/
  |  ___\____|_||_|_| |_|\____|\_/\_/
  |_|
For further information check:
http://www.uclinux.org/ (http://www.uclinux.org/
Command: inetd &
[18]
Command: mkdir /nios2bin
Command: mount -t nfs -n -o nolock,rsize=1024,wsize=1024 192.168.50.62:/home/ucl
inux/nios2bin /nios2bin
eth0: link up, 100Mbps, full-duplex, lpa 0x45E1
Command: boa &
[21]
Command:
Execution Finished, Exiting
Sash command shell (version 1.1.1)
/>[/b]
--- Quote End ---
Also, I added
nod /dev/btn 666 0 0 c 62 0
in romfs_list
After booting, check /dev dir, btn seems to be there.
When I did cat /proc/devices, I get
--- Quote Start ---
/> cat /proc/devices
Character devices:
  1 mem
  2 pty
  3 ttyp
  5 /dev/tty
  5 /dev/console
10 misc
89 i2c
232 ttyJ
240 iodata
241 iodir
250 LCD_PIO[/b]
--- Quote End ---
And when I did cat /proc/interrupts, I get
--- Quote Start ---
  :          0  spurious
  0:      15431 L timer
  1:        24  jtag_uart
  2:        30  pio_button
  6:        602 L eth0
  7:          1  Opencores I2C[/b]
--- Quote End ---
I also read the aritcle in icwin by Wyouken.
http://www.icwin.net/source/pdf/nios2_linu...nux_nios2_3.pdf (http://www.icwin.net/source/pdf/nios2_linux/run_uclinux_nios2_3.pdf
So, it seems that the driver is NOT loaded. Can you help ?
