iperf compile issues
Hi All,
I am having difficulty compiling iperf application using C++ compiler. It is a network monitoring tool included in uClinux distribution. It seems there several problems with compiling this application due to pthread dependencies. I resolved these issues by manually applying a patch. At the moment I am having problems linking the iostream library. I searched through the distribution and did not find an iostream library. Has anyone compiled this application using C++ compiler? I would appreciate your feedback on this issue.
The error is
/opt/nios2.new/bin/../lib/gcc/nios2-linux-uclibc/3.4.6/../../../../nios2-linux-uclibc/bin/ld.real: cannot find -liostream
configure:1981: error: C++ compiler cannot create executables
Here is the relevant information from “config.log”
configure:1903: $? = 0
configure:1905: nios2-linux-uclibc-g++ -v </dev/null >&5
Reading specs from /opt/nios2.new/bin/../lib/gcc/nios2-linux-uclibc/3.4.6/specs
Configured with: /root/buildroot/toolchain_build_nios2/gcc-3.4.6/configure --prefix=/opt/nios2 --build=i386-pc-linux-gnu --host=i386-pc-linux-gnu --target=nios2-linux-uclibc --enable-languages=c,c++ --disable-__cxa_atexit --enable-target-optspace --with-gnu-ld --disable-shared --disable-nls --enable-threads --enable-multilib
Thread model: posix
gcc version 3.4.6
configure:1908: $? = 0
configure:1910: nios2-linux-uclibc-g++ -V </dev/null >&5
nios2-linux-uclibc-g++: `-V' option must have argument
configure:1913: $? = 1
configure:1936: checking for C++ compiler default output file name
configure:1939: nios2-linux-uclibc-g++ -O2 -g -Dlinux -D__linux__ -Dunix -D__uClinux__ -DEMBED -I/home/pganesh/mandala/trunk/software/uClinux-new-slave -I/home/pganesh/mandala/trunk/software/uClinux-new-slave/include -fno-builtin -Dfork=vfork -D__adjtimex=adjtimex -DBB_NOMMU -O2 -g -Dlinux -D__linux__ -Dunix -D__uClinux__ -DEMBED -I/home/pganesh/mandala/trunk/software/uClinux-new-slave -I/home/pganesh/mandala/trunk/software/uClinux-new-slave/include -fno-builtin -Dfork=vfork -D__adjtimex=adjtimex -DBB_NOMMU -Wl,-d -Wl,-elf2flt conftest.cc -L/home/pganesh/mandala/trunk/software/uClinux-new-slave/lib -L/home/pganesh/mandala/trunk/software/uClinux-new-slave/lib/libnet -L/home/pganesh/mandala/trunk/software/uClinux-new-slave/lib/libdes -L/home/pganesh/mandala/trunk/software/uClinux-new-slave/lib/libaes -L/home/pganesh/mandala/trunk/software/uClinux-new-slave/lib/libpcap -L/home/pganesh/mandala/trunk/software/uClinux-new-slave/lib/libssl -lstdc++ -liostream -lio -liberty -lc -lgcc >&5
collect2: ld returned 1 exit status
configure:1942: $? = 1
configure: failed program was:
| /* confdefs.h. */
|# define PACKAGE_NAME "Iperf"
|# define PACKAGE_TARNAME "iperf"
|# define PACKAGE_VERSION "2.0.2"
|# define PACKAGE_STRING "Iperf 2.0.2"
|# define PACKAGE_BUGREPORT ""
|# define PACKAGE "iperf"
|# define VERSION "2.0.2"
| /* end confdefs.h. */
| int
| main ()
| return 0;
See `config.log' for more details.
There is no such issue with current nios2 uClinux-dist. Please follow the nioswiki and update.
- Hippo
I am facing issues with Iperf when I run the device under test as UDP streamer and iperf as the server I get the following error at the server end:
[root@localhost src]# iperf -s -u -i 1
Server listening on UDP port 5001
Receiving 1470 byte datagrams
UDP buffer size: 108 KByte (default)
terminate called after throwing an instance of 'std::bad_alloc'
what(): St9bad_alloc
Aborted
Could you throw some light on what might be going wrong here.
Thank you,
Suneel.
Out of memory?? That's a pretty big buffer...
