jtag_uart bitrate
what is the theoretical maximum bit rate for jtag_uart ip in sopc? assuming no other IP is using the usb-blaster cable.
currently I'm sending data from NiosII to computer using jtag-uart and jtag-atlantic. however I need to know the exact bit rate.
Adel
Exact is a strict word. You'll find an estimation of 0.5 to 1 Mbps for the high speed image download demo example:
http://www.nioswiki.com/exampledesigns/highspeedimagedownloaddemo
thanks for your prompt response.
I tried to push jtag-uart to see if I could squeeze any more bits out of it.
at best, it gives around 150-160KB which is equals to 1.2-1.3 Mbps.
it's roughly 80% utilization of usb-blaster cable considering the bandwidth of USB 1.0 is ~1.5Mbps. (usb-blaster is usb1, right?)
Nios2/f is clocked at 150MHz on a cyclone III fpga (sg=2). jtag-uart has 1k buffer.
also all ip-cores that might use the usb-blaster (like signal tap) are turned off.
USB Blaster is uses Full Speed USB (FTDI FT245), but the JTAG speed is limited to 6 MHz by the USB Blaster Hardware. Furthermore there is a considerable overhead of the virtual JTAG protocol transferring the UART payload with a word length of 8-Bit only.
