kbhit() in C
I searching for an implementation of kbhit() from <conio.h> in C. I want to use this function for the Terminal in the eclipse IDE.
http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/rolleyes.gif Thx a lot for your help
I&#39;m not sure if i understand you correctly but take a look at the "Board Diagnostics"-Template in Nios II IDE. There is a function called getchar() used for this.
Hi cece,
Thx for your answere. But getchart don&#39;t solve my problem, because its a blocking function. This means, if no key is pressed, the function getchar blocks until a key is pressed. With kbhit it is possible just to test, if an key was pressed(without blocking).
-> with the help of <termios.h> it should be possible to programm a kbhit function, but the functions :
- tcgetatt
- tcsetattr
from termios.h doesnt&#39;t work ??? Any other solutions are welcome
Here the code :
int getch()
static int ch = -1, fd = 0;
struct termios neu, alt;
fd = fileno(stdin);
tcgetattr(fd, &alt);
neu = alt;
neu.c_lflag &= ~(ICANON|ECHO);
tcsetattr(fd, TCSANOW, &neu);
ch = getchar();
tcsetattr(fd, TCSANOW, &alt);
return ch;
int kbhit(void)
struct termios term, oterm;
int fd = 0;
int c = 0;
tcgetattr(fd, &oterm);
memcpy(&term, &oterm, sizeof(term));
