12745 Discussions
kernel crash when running pppd with debug option
I have compiled pppd and I have some problems with it.
It seems to work ok, but when I try to run it with the "debug" option it crashes the kernel after connection is established. I don't get any crash if I remove this option. This is quite annoying since I can't debug it properly ...
I have tried with the version from uClinux-dist (2.3.8) and with the version from buildroot (2.4.3 that I had to patch). Both crash the kernel, but with the 2.4.3 version I also get a kernel crash when I try to use a connect script that uses chat.
I thought this kind of software was really stable, does anybody have an idea of where the problem might come from ? For information, I first had a kernel crash with no warning because I forgot to activate the 'support for console on Nios UART' kernel option. I find it strange that such a software does no such check before running...
Thanks a lot,
Regrards,
Pod
Do you get crash message dump?
Please try increase the elf2flt stack size.
Hi hippo,
thanks for the help. I don't get any error message before the crash, I just see that the console is down (no response to anything).
I tried to increase the stack size to 256k, but I still get the same problem.
Thanks again, I ll look further.
Pod
