12748 Discussions
kernel image in SDRAM but not booting?
Hello:
I have used the u-boot successully coping the uclinux kernel image from flash to sdram .I verified the contents at and near the start address of the sdram , same with the kernel image.bin using the ultraedit,md.b command.But the kernel stop .I see the file nios_linux.c I don't know what is the function kernel() ,also I can't find source file .
Let me know why if you have any more ideas on this...
Thank you !
Best Regards
jigdo
The next problem :
I use go command but error below:
*****warning unimplemented trap @ 0x100015c
# # Application terminated, rc = 0xFFFFFF82
my sdram base_addr 0x1000000
Best Regards
jigdo
Hi jigdo,
First ... what version of u-boot are you using, and where did you get it from?
How did you do this? You must use the bootm command to correctly boot a kernel.
> But the kernel stop
What does this mean? Please provide some details -- it is difficult for us to guess what you
are observing ;-)
The _variable_ "kernel" is a function pointer ... it points to the entry point of the kernel. When
you create a u-boot kernel image with mkimage, you specify this address with the -e option.
Please provide more details ... what address did you specify? ... what is at the address
that you specify? What are you trying to do?
--Scott
Hi scott:
First
I use bootm command to boot a kernel:
bootm BASE_ADDR_SDRAM
>But the kernel stop
are observing ;-)
when the code run to the function kernel( ), in the nios2-terminal :
the last line :
Uncompressing Kernel Image ...........OK
cursor wink
I use the printf("%08x\n",hdr->ih_ep);
the hdr->ih_ep is 0x000000001 (entry_point should be 0x1000000 (BASE_ADDR_SDRAM ) )
I think the method is wrong .
Besides ,I use the nios2-flash-programmer to download the u-boot and kernel.
in the mkimage,the load_address and the entry_address both are BASE_ADDR_SDRAM.
Best Regards
jigdo
Hi jigdo,
I _think_ I understand ... but I'm not sure. Based on your comments, you should be doing the
following:
-Use the flash programmer to download your compressed u-boot kernel image to flash.
This is the binary file you create using mkimage.
-From the u-boot command line, you should specify the address (in flash) of the image file.
This tells u-boot to read the image from flash, uncompress it and write the uncompressed data
to the "load address". U-boot will then disable interrupts, and jump to the "entry point address".
When you try to uncompress a u-boot image to the same address as the u-boot image,
the uncompressed data will overwrite the compressed data ... and bad things will happen ;-)
--Scott
Hi scott:
Can you tell me where can I find the source code of "ntohl( )"?
the hdr->ih_ep is 0x000000001 but the entry address is 0x1000000 (base_addr_sdram)
I don't know why?
Best Regards
jigdo
Hi jigdo,
Please post the result of the imi command for your u-boot kernel image. E.g. if your compressed
kernel image is at address 0x00200000:
==> imi 200000
And post the result of a mkimage list. E.g. if your image file name is kernel.img:
$ mkimage -l kernel.img
> I don't know why?
It looks like an endian order problem. Did you build the mkimage utility yourself, or are you
using the pre-built version from psyent.com
--Scott
Hi scott:
I use the u-boot-1.1.3 downloaded from www.souceforge.net
I see the readme the mkimag command used as fellow:
mkimage -A ppc -O linux -T kernel -C gzip
-a 0 -e 0 -n "Linux Kernel Image"
-d linux.bin.gz uImage
I think the uImage file also is .bin type file,so I use bin2flash comand convert the uImage to uImage.flash,then download to .flash file use nios2-flash-programmer .
I don't have the .img file.
I am sure the niosII is little endian,because in the vmlinux.lds file , "OUTPUT_FORMAT("elf32-littlenios2", "elf32-littlenios2", "elf32-littlenios2")"
Best Regards
jigdo
Hi jigdo,
Based on your previous posts, this should be:
mkimage -A nios2 -O linux -T kernel -C gzip
-a 0x1000000 -e 0x1000000 -n "Linux Kernel Image"
Correct.
It is the uImage file ... the output of mkimage.
This is irrelevant. It is the header that is apparently incorrect (which is always stored
in network byte order by mkimage).
Again, if you post the results of imi and mkimage -l, I may be able to help.
--Scott
Hi, scott
I got the same error. And I am from China,too. (cannot surf http://www.pysent.com) (http://www.pysent.com))
Could you send me the patch to other1999@163.com or jiangweiquan@hotmail.com, thank u.
<div class='quotetop'>QUOTE </div>
--- Quote Start ---
In file included from /usr/include/sys/unistd.h:9,
????????from /usr/include/unistd.h:6,
????????from img2srec.c:61:
/usr/include/sys/types.h:106: conflicting types for `int8_t&#39;
/usr/include/stdint.h:38: previous declaration of `int8_t&#39;
/usr/include/sys/types.h:108: warning: redefinition of `int16_t&#39;
/usr/include/stdint.h:39: warning: `int16_t&#39; previously declared here
/usr/include/sys/types.h:110: warning: redefinition of `int32_t&#39;
/usr/include/stdint.h:40: warning: `int32_t&#39; previously declared here
/usr/include/sys/types.h:112: warning: redefinition of `int64_t&#39;
/usr/include/stdint.h:45: warning: `int64_t&#39; previously declared here
make[1]: *** Error 1
make[1]: Leaving directory `/cygdrive/d/My_Project/MtxCyclone_uBoot/BootLoader/u-boot-1.1.3/tools
make: *** [tools] Error 2[/b]
--- Quote End ---
Hi mountain8848,
Done ... you&#39;re more than welcome.
--Scott
BTW: The main u-boot source tree is no longer at sourceforge.net ... it has been moved
to denx.net and is now using git (a welcome change). For details please see:
http://sourceforge.net/mailarchive/message...msg_id=12658390 (http://sourceforge.net/mailarchive/message.php?msg_id=12658390)
Hi, Scott
I boot uClinux sucessfully by u-boot . Thank you again.
My steps:
1. Modify <u-boot>/include/configs/PK1C20.h to meet my custom board
2. make PK1C20_config
3. make
4. Start HyperTerminal with the following settings:
baudrate : 115200
parity : None
data bits : 8
stop bits : 1
flow cntl : None
5. nios2-download -g u-boot
I saw the command promt "==>". :-)
TODO:
My custom board using Davicom&#39;s DM9000A(DM9000X serials). I&#39;d like to using tftp by U-boot. So:
1. copy dm9000x.c dm9000x.h from original u-boot 1.3.1
2. modify some codes to remove some errors and meeting my custom board
3. make
4. nios2-download -g u-boot
5. in the terminal:
==> ping 218.192.171.46
dm9000 not found at 0x00200920 id: 0xffffffff
MAC: ff:ff:ff:ff:ff:ff
operating at unknown: 15 mode
transmission timeout
ping failed; host 218.192.171.46 is not alive
* Maybe IO routes doesn&#39;t work well.
* Another questions, I using MTD patitions over Flash. How can I access patitions in u-boot ? and How in uClinux?
* I need egrep in cygwin, but this version of cygwin dose not provide egrep. I copy egrep from redhat, but not worked. what&#39;s your suggestions?
regards,
Will
Hi Will,
Yes, there was lots of driver code that was removed from the u-boot sources at psyent.com
mostly to keep the tarball size reasonable. But you should always be able to grab the latest
driver code from the main u-boot source tree and just copy it into your local sources.
Perhaps, you might also want to define the CONFIG_DM9000_BASE macro using cache
bypass (if you are using data cache). E.g.
# define CONFIG_DM9000_BASE 0x80200920
Also, you must correctly define CONFIG_DM9000_USE_xxBIT (for the bus width).
E.g.:
# define CONFIG_DM9000_USE_32BIT
If your bus width is not 32-bit, make sure you are using native alignment rather than
the memory/dynamic alignment.
I have never used this driver in u-boot ... you may need to define CONFIG_DM9000_DEBUG
to track down any issues.
This has recently changed in u-boot ... but I believe the following should still work:
- CFG_CMD_JFFS2 to CONFIG_COMMANDS
- define CFG_JFFS_CUSTOM_PART
- the in one of your board-specific modules, something like this:#if (CONFIG_COMMANDS & CFG_CMD_JFFS2) && defined(CFG_JFFS_CUSTOM_PART) static struct part_info parts = {        {        /* system partition */                .size    = 0x00600000,                .offset    = (char *)(CFG_FLASH_BASE + 0x00200000),        },        {        /* /usr/local partition */                .size    = 0x00040000,                .offset    = (char *)(CFG_FLASH_BASE + 0x00800000),        } }; static int numparts = sizeof(parts)/sizeof(struct part_info); struct part_info *jffs2_part_info (int part_num) {        struct part_info *info = NULL;        if (part_num < numparts)                info = &parts;        return (info); } # endif /* (CONFIG_COMMANDS & CFG_CMD_JFFS2) */ Then you should be able to use the u-boot ls, fsload, etc. commands. To switch between the
active partition, use the chpart command.
BTW: in u-boot you can define a partition in ram/sdram to test your images prior to performing any
flash programming.
For linux, you will have to write your own mapping driver.
--Scott
