12610 Discussions
limit the linux partition in DDR3 memory of DE1-SOC board
how can i devide the ddr3 memory between the linux and FPGA in DE1 soc board
You can limit the memory reserved for linux by specifying the "mem" parameter when booting the linux kernel eg.
bootargs root=/dev/mmcblk0p2 rw rootwait console=ttyS0,115200 mem=800M
Documented here https://www.kernel.org/doc/html/v4.14/admin-guide/kernel-parameters.html (https://www.kernel.org/doc/html/v4.14/admin-guide/kernel-parameters.html) (Search for "mem=")
Hii Tototo
Using the cable ethernet not the uart can i use this command ?
this command limit the linux to use just 800M of the DDR3 memory?
so to which adress i can write to ddr3 memory from the FPGA ?
--- Quote Start ---
--- Quote End ---
You can set these parameters from within uBoot, independently from your connection.
If you type "printenv" within uBoot you will see the entire environment variables. Probably you can spot some variables that are used for booting the kernel eg. name of the kernel image, boot parameters....
--- Quote Start ---
so to which adress i can write to ddr3 memory from the FPGA?
--- Quote End ---
You can verify this by typing
cat /proc/iomem
It should say something like "00000000-31ffffff : System RAM" and that is the memory range used by kernel. You can do with the rest whatever you want.
Hii Tototo ,
when I type this command "cat /proc/iomem" it gives me
root@socfpga:~# cat /proc/iomem
00008000-006ed827 : Kernel code
00744000-007c355b : Kernel data
ff702000-ff703fff : /soc/ethernet@ff702000
ff704000-ff704fff : /soc/dwmmc0@ff704000
ff705000-ff705fff : ff705000.spi
ffa00000-ffa00fff : ff705000.spi
ffb40000-ffb4fffe : /soc/usb@ffb40000
ffc00000-ffc00fff : c_can_platform
ffc02000-ffc0201f : serial
ffc04000-ffc04fff : /soc/i2c@ffc04000
ffc05000-ffc05fff : /soc/i2c@ffc05000
ffd02000-ffd02fff : /soc/wd@ffd02000
ffe01000-ffe01fff : /soc/amba/pdma@ffe01000
fff01000-fff01fff : fff01000.spi
ffff0000-ffffffff : /soc/sram@ffff0000
means that i can do with the 0x32000000-0x40000000 whatever i want
--- Quote Start ---
--- Quote End ---
As this range is not used by Linux Kernelspace nor Userspace it will have no impact on the behavior of the system.
And still you can access this memory from within linux by its address :)
