links web browser problem?
links web browser
Network Applications --->
[*] links
This is a fast, lightweight text and graphical web-browser.
I choose links in my uclinux,but i did not success.
../links-2.1pre32//configure: line 6803: /quartus/1/nios2-linux/uClinux-dist/tools/nios2-linux-uclibc-pkg-config: No such file or directory
*** Your version of pkg-config is too old. You need version 0.9.0 or newer.
../links-2.1pre32//configure: line 6896: /quartus/1/nios2-linux/uClinux-dist/tools/nios2-linux-uclibc-pkg-config: No such file or directory
checking for png.h... yes
checking for libpng/png.h... no
checking for png_create_info_struct... no
checking for png_create_info_struct in -lpng... yes
checking for png_set_rgb_to_gray... yes
checking for png_get_image_width... yes
checking for png_get_image_height... yes
checking for png_get_gAMA... yes
checking for png_get_color_type... yes
checking for png_get_bit_depth... yes
checking for png_set_strip_alpha... yes
checking for png_get_valid... yes
checking for png_get_sRGB... yes
checking if you can include both setjmp.h and png.h... no
checking for jpeglib.h... yes
checking for jpeg_destroy_decompress in -ljpeg... yes
checking for tiffio.h... no
checking for TIFFClientOpen in -ltiff... no
configure: error: No graphics drivers found.
make[3]: *** [build-links-2.1pre32//Makefile] 错误 1
make[3]: Leaving directory `/quartus/1/nios2-linux/uClinux-dist/user/links'
make[2]: *** [links] 错误 2
make[2]: Leaving directory `/quartus/1/nios2-linux/uClinux-dist/user'
make[1]: *** [all] 错误 2
make[1]: Leaving directory `/quartus/1/nios2-linux/uClinux-dist/user'
make: *** [subdirs] 错误 1
http://www.alteraforum.com/forum/showthread.php?t=25067
I have make it , see my post above
