12745 Discussions
lwIP, uCOSII and task priority ranges
Came over this while trying to figure out why object "sys_stack" occupied half my RAM size in the .elf.
In sys_arch.h:
# define LWIP_MAX_TASKS OS_LOWEST_PRIO /* Number of LwIP tasks */# define LWIP_START_PRIO 0 /* Defined the lowest LwIP task priority */# define LWIP_STACK_SIZE 2048 /* Stack size for LwIP tasks */
/* Note:
Task priorities, LWIP_START_PRIO through (LWIP_START_PRIO+LWIP_MAX_TASKS-1) must be reserved
for LwIP and must not used by other applications outside. */
In sys_arch.c:
OS_STK sys_stack[LWIP_MAX_TASKS][LWIP_STACK_SIZE];
So, this explains my big sys_stack, since I have set OS_LOWEST_PRIO to 63.
My question now, however, is:
If you reserve the range 0 to OS_LOWEST_PRIO for lwIP tasks, is there any prios left for other tasks? Presumption: OS_LOWEST_PRIO = highest number any task can have for priority.
Frode,
Norway
Have put my task priorities closer together and reduced OS_LOWEST_PRIO, hence making sys_stack smaller and saving memory. Did not change anything in sys_arch.*
All tasks seems to work in harmony.
Is it so that lwIP doesn't use any other priorities than those I can control from the app as arguments to lwip_stack_init(), lwip_devices_init() and calls to sys_thread_new()?
In case the Note comment in sys_arch.h makes any sense, wouldn't the constant LWIP_MAX_TASKS be better off configured from the IDE, rather than set to OS_LOWEST_PRIO?
Frode,
Norway
