hi,
I use the standalone lwip example from the download area here, it works fine with the webserver example. Now i am writing my own application and i need to do an active open (tcp_connect) to a server. When my application sends the "SYN" flag, the Server answeres very fast with "SYN ACK" flag (thats normal) -> now my application needs exactly 2,5 seconds to answere with a "ACK" flag and i don' know why it takes soooooo long. i i can't find the error. Heres my code : void test_init(void) { struct ip_addr ipa; struct tcp_pcb *pcb2; u16_t port; err_t error; port = 21; IP4_ADDR( &ipa, 192, 168, 1, 50 ); pcb2 = tcp_new(); tcp_bind(pcb2, IP_ADDR_ANY, 1362); error = tcp_connect(pcb2,&ipa,port,ftp_connect); } P.S. i didn't changed the lwip_web_server.c . i just replaced the httpd_init() call with the test_init() call Thx for your helpLink Copied
