make error!!!
make menuconfig
make //custom fpga
MODPOST vmlinux.o
WARNING: modpost: Found 4 section mismatch(es).
To see full details build your kernel with:
'make CONFIG_DEBUG_SECTION_MISMATCH=y'
GEN .version
CHK include/linux/compile.h
UPD include/linux/compile.h
CC init/version.o
LD init/built-in.o
LD .tmp_vmlinux1
/mywork/nios2-linux/toolchain-mmu/x86-linux2/bin/nios2-wrs-linux-gnu-ld:arch/nios2/kernel/vmlinux.lds:226: ignoring invalid character `#' in expression
/mywork/nios2-linux/toolchain-mmu/x86-linux2/bin/nios2-wrs-linux-gnu-ld:arch/nios2/kernel/vmlinux.lds:226: syntax error
make[2]: *** [.tmp_vmlinux1] 错误 1
make[1]: *** [sub-make] 错误 2
make[1]: Leaving directory `/mywork/nios2-linux/linux-2.6'
make: *** [linux] 错误 1
why??
HAVE deal with it
the comment must use /* ... */
must not like //...
thanks
i have the same problem:
GEN .version
CC init/version.o
LD init/built-in.o
LD .tmp_vmlinux1
/home/emil_kruki/nios2-linux/toolchain-mmu/x86-linux2/bin/nios2-linux-gnu-ld:arch/nios2/kernel/vmlinux.lds:192: syntax error
make[2]: *** [.tmp_vmlinux1] Fehler 1
make[1]: *** [sub-make] Fehler 2
make[1]: Leaving directory `/home/emil_kruki/nios2-linux/linux-2.6'
make: *** [linux] Fehler 1
emil_kruki@hws-162:~/nios2-linux/uClinux-dist>
but there are only 130 lines in vmlinux.lds.S, and in file vmlinux.lds.h i can not recognize an syntax error....
you are looking in the wrong directory..
look under /nios2-linux/uClinux-dist/linux-2.6.x/arch/nios2/kernel
and find file vmlinux.lds
change comments from
//#define ...
to
/*#define ... */
I had about 7 lines to change around line 302 and it solved the problem.
