make vendor_hwselect problem
I take the BinaryToolchain for building kernel,when i take the step:
make vendor_hwselec SYSPTF=~/your_hardware_project/your_system.ptf
I use the nios_0.ptf for DE2_NET project,and this file is in uClinux-dist dir
Then i do as these:
[nios@www uClinux-dist]$ make vendor_hwselect SYSPTF=nios_0.ptf
But errors happend:
make ARCH=nios2nommu -C vendors vendor_hwselect
make[1]: Entering directory `/home/nios/download/uClinux-dist/vendors'
make -C /home/nios/download/uClinux-dist/vendors/Altera/nios2nommu/. dir_v=/home/nios/download/uClinux-dist/vendors/Altera/nios2nommu/. -f /home/nios/download/uClinux-dist/vendors/vendors-common.mak vendor_hwselect
make[2]: Entering directory `/home/nios/download/uClinux-dist/vendors/Altera/nios2nommu'
make ARCH=nios2nommu CROSS_COMPILE=nios2-linux-uclibc- -C /home/nios/download/uClinux-dist/linux-2.6.x hwselect
no emulation specific options.
make[3]: Entering directory `/home/nios/download/uClinux-dist/linux-2.6.x'
RUNNING hwselect
ERROR: Could not open SYSTEM ptf file.
make[3]: Leaving directory `/home/nios/download/uClinux-dist/linux-2.6.x'
make[2]: Leaving directory `/home/nios/download/uClinux-dist/vendors/Altera/nios2nommu'
make[1]: Leaving directory `/home/nios/download/uClinux-dist/vendors'
what is wrong? thank you!!!
You must give the path of the ptf. Put the ptf in uClinux-dist dir won't work, because it will cd to kernel dir.
eg, SYSPTF=~/your_de2_project/xxxx.ptf
