menuconfig question
I just started with the latest uClinux-dist after abandoning the microtronix build. I've applied the nios2 patches and selected Altera and nios2nommu in the top menuconfig, but when I cd linux-2.6.x and make menuconfig there, there is no option for NiosII in the the processor family menu. I do, however, see other devices in other hardware menus like DM9000a, etc. Did I do something wrong or should I just ignore this?
Thanks in advance :]
(still in uClinux-dist dir, DO NOT cd linux-2.6.x)
make menuconfig
Kernel/Library/Defaults Selection --->
(linux-2.6.x) Kernel Version
(None) Libc Version
[ ] Default all settings (lose changes)
[*] Customize Kernel Settings
[*] Customize Vendor/User Settings
[ ] Update Default Vendor Settings
Then <exit> <exit> <yes> .
