12748 Discussions
modifying advanced bootcopier ,booting from EPCS
Background:
I am developing a project with two separate boot images building from two application software. The two images are stored in EPCS64, I need to boot one image from the EPCS64 at the designated address.
I use Quartus 12.0,Sopc builder configure my FPGA hardware system.
I have read the technology document "Alternative Nios II Boot Methods " and download the example.
Desired solution:
How can I modify the example to build my own advanced bootcopier with command shell?
Are there any documents about this?
How do I compile the bootcopier_bsp_settings.tcl ?
Thank you very much!
Is there anyone encounter the same problem ?Thanks.
