with the Mircrotronix cross compile chain I'm trying to compile net-snmp 5.2.2. I get the following error when creating the libnetsnmp.so : /usr/local/nios2[long path]/3.4.3/[long path]nios2-linux-uclibc/lib/crt0.o in function _start : undefined reference to main. /usr/local/nios2[long path]/3.4.3/[long path]nios2-linux-uclibc/lib/libc.a in function __uClibc_start_main : undefined reference to main. Any hint how can I fix those errors? Thanks for helping BzhLink Copied
--- Quote Start --- originally posted by temex@Dec 5 2005, 10:57 AM hi,
with the mircrotronix cross compile chain i'm trying to compile net-snmp 5.2.2.
i get the following error when creating the libnetsnmp.so :
__uclibc_start_main
any hint how can i fix those errors?
thanks for helping
bzh
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=11329)
--- quote end ---
--- Quote End --- The build process is trying to build a shared library (that is what the .so extension means), and those are not supported. Try enabling static compilation instead.
--- Quote Start --- originally posted by lpearson@Dec 9 2005, 11:26 AM the build process is trying to build a shared library (that is what the .so extension means), and those are not supported. try enabling static compilation instead.
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=11456)
--- quote end ---
--- Quote End --- Thanks Marc
hi temex:
I want to use NET-SNMP in nios2. please share your experience and reult. Thanks a lot. Alex- Mark as New
hi,
just download the latest net-snmp sources 5.2.2. edit config.sub: add "| nios2" in the "case $basic_machine in" run: ./configure --host=nios2-linux --with-cc=nios2-linux-gcc --disable-shared -enable-static --with-endianness=little compile and seems to work fine. (works under linux not cygwin) good luck, marc- Mark as New
--- Quote Start --- originally posted by temex@Dec 14 2005, 04:00 AM hi,
edit config.sub:
run:
good luck,
marc
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=11532)
--- quote end ---
--- Quote End --- Thank you very much http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/smile.gif
