12748 Discussions
nios2-bsp not finding user components in 9.1?
I am porting my class.ptf files into hw.tcl and sw.tcl files going from 7.1 (with 6.1 classic components) to 9.1.
It does not appear that the nios2-bsp command is finding my sw.tcl files as it does not copy the include/source files over and does not reference the INSTANCE and INIT functions in alt_sys_init.c
I know that my sopc builder path is setup properly as the SOPC builder itself finds my user components both the classic ones and the new ones with hw.tcl files.
I have tried copying a couple of my sw.tcl file to my quartus/ip directory but that didn't work either.
I also tried compiling a new 9.1 component with a hw.tcl file into the SOPC project thinking that maybe the bsp could not find sw.tcl file if a class.ptf file was in use (but I have seen altera components use class.ptf with sw.tcl file successfully).
nios2-bsp does not complain about not being able to find anything. It completes successfully?
Any ideas on whats wrong or how to debug this? Is there a project setting that needs to be set to enable using INIT and INSTANCE functions?
Sorry for all the questions, seems like one thing after another...
Thanks in advance
jennifer
Where are your components located relative to your SoPC builder system?
Have you tried using the nios2-bsp-editor to create your settings.bsp file? You do need to specifically specify that the BSP is supposed to make use of a software component.
Jake
I use the following command, it makes a settings.bsp file
nios2-bsp hal bsp_diag_rvp9ifd quartus --default_sections_mapping main_ram --set hal.make.bsp_cflags_debug -g --set hal.make.bsp_cflags_optimization -O2
I opened it with an editor, it shows Driver Name = none for my modules? So there is no enable check box next to them.
thanks!
nios2-bsp-editor was very useful in debugging this. I am not used to using the new tools yet. I made a stupid mistake and thought that the version number should be the Nios version number not my component version number due to all the altera examples where their version = nios version.
