12748 Discussions
nios2-configure-sof :command not found
Iam trying to run uclinux on DE0-Nan0 board, i successfully generated the linux image also, but iam unable to generate the bitstream by executing the following command.
nios2-configure-sof ~/uClinux/hardware/DE0-Nano/simple/DE0_Nano.sof but its showing error nios2-configure-sof- command not found, iam using ubutu12.04.
Any help?
Alex.
hi
in you quartus installation path in "nios2eds" folder, run "nios2_command_shell"
directory example: /home/user/altera/12.0/nios2eds/
and then run : ./nios2_command_shell
you can now run"nios2-configure-sof" command
