公告
nios2-elf-gcc: command not found
名誉分销商 II
1,703 次查看
Hello All !
I use Toolchain to build kernel but after
- I install Toolchain
- make menuconfig
- make vendor_hwselect SYSPTF=~/hardware/1c12.ptf
- make romfs
- make
- make 'again'
- make linux image
I got error message " nios2-elf-gcc: command not found" at make romfs - make and make 'again'
I can't load zImage to board because of error "Cannot open root "NULL" or block (0,0) ...
and the most subdir in my romfs dir is empty except romfs/etc
What wrong ???
thanks very much for help !
0 项奖励
1 回复
名誉分销商 II
825 次查看
Hello All !
this is error message when make romfs :
romfs-inst.sh -e CONFIG_USER_FLATFSD_FLATFSD -e CONFIG_USER_TINYLOGIN_S HADOWPASSWDS -s config/shadow /etc/shadow
for i in uClibc /home/vietluong/uClinux-dist/prop ; do
[ ! -d $i ] || make -C $i romfs || exit $? ;
done
/bin/sh: nios2-elf-gcc: command not found
make[2]: Entering directory `/home/vietluong/uClinux-dist/uClibc'
[ -e /home/vietluong/uClinux-dist/romfs/lib ] || mkdir /home/vietluong/ uClinux-dist/romfs/lib
if [ "" ]; then
romfs-inst.sh /lib/lib.so;
fi
make[2]: Leaving directory `/home/vietluong/uClinux-dist/uClibc'
make[1]: Leaving directory `/home/vietluong/uClinux-dist/lib'
make[1]: Entering directory `/home/vietluong/uClinux-dist/include'
make[1]: Nothing to be done for `romfs'.
make[1]: Leaving directory `/home/vietluong/uClinux-dist/include'
make[1]: Entering directory `/home/vietluong/uClinux-dist/user'
for i in boa busybox cgi_generic dhcpcd-new ftp games inetd init sash t elnetd /home/vietluong/uClinux-dist/prop ; do
done
make[2]: Entering directory `/home/vietluong/uClinux-dist/user/boa'
for i in src ; do make -C $i romfs || exit ; done
make[3]: Entering directory `/home/vietluong/uClinux-dist/user/boa/src'
romfs-inst.sh /bin/boa
cp: cannot stat `boa': No such file or directory
make[3]: *** [romfs] Error 1
make[3]: Leaving directory `/home/vietluong/uClinux-dist/user/boa/src'
make[2]: *** [romfs] Error 2
make[2]: Leaving directory `/home/vietluong/uClinux-dist/user/boa'
make[1]: *** [romfs] Error 2
make[1]: Leaving directory `/home/vietluong/uClinux-dist/user'
make: *** [romfs.subdirs] Error 1
PLEAPLE HELP ME !
0 项奖励
回复
