12748 Discussions
nios2-gcc for nios2-uclinux host
Is it possible to run gcc toolkit on nios2-uclunux host?
How can i make it.
--- Quote Start ---
originally posted by nvs@Jul 12 2006, 07:17 PM
is it possible to run gcc toolkit on nios2-uclunux host?
how can i make it.
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=16827)
--- quote end ---
--- Quote End ---
with the limited speed and resource of nios2 system, it is not pratical.
did you ever compile on a 66MHz 486 PC?
On 486(33MHz) module, dos+norton commander and TurboC 2.0 has worked.
Sometimes it can be needed, when PC or notebook inaccessible.
It is not perspective?
--- Quote Start ---
originally posted by nvs@Jul 12 2006, 09:52 PM
on 486(33mhz) module, dos+norton commander and turboc 2.0 has worked.
sometimes it can be needed, when pc or notebook inaccessible.
it is not perspective?
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=16834)
--- quote end ---
--- Quote End ---
Yes, it is possible. ( or nothing impossible).
But it would take a lot of efforts.
if you want some field programming tools, you should think of script interpreters.
eg, python had been ported to uclinux. uClinux-dist/user/python
