nios2_system.h (kernel 2.6.9)
Colaborador honorário II
1.018 Visualizações
A few questions regarding scripts/nios2_system.h/altera_avalon_xxx.pm:
1. It appears naming requirements have changed. Earlier versions allowed
module names such as "timer0", "uart0", etc. The current version will not
translate these names. This (of course) results in compile-time errors as
the address macros are not redefined with the appropriate typecast ... just
the comment "/* No translation for xxx necessary */".
Is this intentional ... a bug? ... any insight would be great :-)
2. I couldn't find documentation regarding name limitations (other than
the comments in perl modules).
Can someone point to the naming requirements (or just post them)? -- thanks.
3. After updating the target ptf (IDE kernel properties), nios2_system.h
was not updated. After deleting nios2_system.h, it was recreated ... but
apparently with the old values.
What (if anything) triggers a nios2_system.h update (other than deleting it)?
--Scott
0 Respostas
Responder
