12745 Discussions
operate UART w/ NIOS wo/ HAL
The following code should make a loopback between UART RX and TX (echo).
However, it seems that first N typed chars (from PC towards the board) are not successfully absorbed.
After N characters (few dozens, I guess), it works correctly (I get an echo for each character I type).
Any ideas?
# include "altera_avalon_uart_regs.h"# include "system.h" typedef unsigned char u8; typedef unsigned short u16; typedef unsigned int u32; # define UART_BASE UART_0_BASE int main () { u8 uart_rx_char; u16 uart_st_reg; while (1) { uart_st_reg = (u16)IORD_ALTERA_AVALON_UART_STATUS(UART_BASE); if (uart_st_reg & ALTERA_AVALON_UART_STATUS_RRDY_MSK) { uart_rx_char = (u8)IORD_ALTERA_AVALON_UART_RXDATA(UART_BASE); IOWR_ALTERA_AVALON_UART_TXDATA(UART_BASE, uart_rx_char); } } return 0; }
try to check if transmit is ready before you write in your txdata, and clear the status register in the begining of your while.
