partitioning CF card error
hi, hippo
when I partition CF card in the last step by entering "w" at the main prompt. it showns below:
"The partition table has been altered!
Calling ioctl<> to re-read partition table.
hda:unknown partition table
warning: if you have created or modified any DOS 6.x partitions please see the fdisk manual page foe additonal information.
Syncing disks."
what shall I do?
Those look like typical Linux warnings, except for the first bit. If you type fdisk <your dev> and then type "p", what does that show? If you were successful, you should see a listing of all partitions on your card. From this point, you should be able to format your partition(s) and get on with the flow.
Good luck!
- slacker
--- Quote Start ---
originally posted by slacker@Jun 28 2006, 12:20 AM
those look like typical linux warnings, except for the first bit.  if you type fdisk <your dev> and then type "p", what does that show?  if you were successful, you should see a listing of all partitions on your card.  from this point, you should be able to format your partition(s) and get on with the flow.
good luck!
- slacker
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=16435)
--- quote end ---
--- Quote End ---
thanks!
when I fdisk CF card:
"#fdisk /dev/hda
device contains neither a valaid DOS partition table, or Sun,SGI or OSF disklabel
Building a new DOS disklabel. Changes will remain in memory only, until you decide to write them. After that, of coure, the previous content will not be recoverable.
can u help me?
thanks!
First a quick question:
You&#39;re trying to do this from a Linux host, right?
- Not uCLinux! While it may be possible to format a CF card, from within uCLinux, it&#39;s certainly not advisable.
Things to check:
1. Be sure that you&#39;re fdisking the correct device.
- scan the output of the &#39;dmesg&#39; command to make sure that your CF card is being properly detected. You should see something like the following:
SCSI device sdg: 3978240 512-byte hdwr sectors (2037 MB) sdg: Write Protect is off sdg: Mode Sense: 02 00 00 00 sdg: assuming drive cache: write through SCSI device sdg: 3978240 512-byte hdwr sectors (2037 MB) sdg: Write Protect is off sdg: Mode Sense: 02 00 00 00 sdg: assuming drive cache: write through
Pay attention to the name of the device as that is how you&#39;ll access it. NOTE: There is some amount of variation to the drive letter chosen, based upon boot order or when you connected your card reader.
2. Be sure that you don&#39;t have some sort of media issue with the CF card. Try formatting it from within Windows....or from a digital camera...or whatever. You just want to make sure this is successful, before trying on Linux, again.
- If successful, you should be able to "mount" the drive, on your Linux host, and copy files onto it.
Best of luck...
- slacker
--- Quote Start ---
originally posted by slacker@Jun 28 2006, 12:53 PM
first a quick question:
you&#39;re trying to do this from a linux host, right?
  - not uclinux!  while it may be possible to format a cf card, from within uclinux, it&#39;s certainly not advisable.
things to check:
1.  be sure that you&#39;re fdisking the correct device.
  - scan the output of the &#39;dmesg&#39; command to make sure that your cf card is being properly detected.  you should see something like the following:
scsi device sdg: 3978240 512-byte hdwr sectors (2037 mb) sdg: write protect is off sdg: mode sense: 02 00 00 00 sdg: assuming drive cache: write through scsi device sdg: 3978240 512-byte hdwr sectors (2037 mb) sdg: write protect is off sdg: mode sense: 02 00 00 00 sdg: assuming drive cache: write through
pay attention to the name of the device as that is how you&#39;ll access it.  note:  there is some amount of variation to the drive letter chosen, based upon boot order or when you connected your card reader.
2.  be sure that you don&#39;t have some sort of media issue with the cf card.  try formatting it from within windows....or from a digital camera...or whatever.  you just want to make sure this is successful, before trying on linux, again.
    - if successful, you should be able to "mount" the drive, on your linux host, and copy files onto it.
best of luck...
- slacker
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=16452)</div>
--- Quote End ---
thanks
