12748 Discussions
pre build binary chain problem
hello all
Im trying to install the nios2gcc to my laptop with has Ubuntu Linux on it
my laptop is AMD Turion X2
I followed the instructions on the wiki and changed the PATH variables to point to the folder /opt/nios2/bin
when I echo PATH thats what I get:
/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/games:/opt/nios2/bin:/opt/nios2/bin
but when i type the command
$ nios2-linux-uclibc-gcc -v
get the following line:
bash: /opt/nios2/bin/nios2-linux-uclibc-gcc: no such file or directory
can please somebody tell me what im doing wrong , im sure may be im missing something , i new to the uclinux and nios2 tools
thanks
ehab
Is it actually there?
ls /opt/nios2/bin
yes it is there , it is there and even I go inside /opt/nios2/bin
and still when i make nios2-linux-uclibe-gcc -v
still same thing
Hi everyone,
I've got the same problem. Is there any solution?
My system is is Ubuntu as well and I'm running it in a Virtual Box as guest.
I'm pretty confuesd since the files are all in the place there should be and can be listed with ls etc.
What are the permissions on the executable "nios2-linux-uclibc-gcc"? Do an "ls -altr" in the "/opt/nios2/bin" directory. If you don't see "x" as one of the permission bits, execution isn't possible, even if it's a valid executable file. To change it, type "chmod +x nios2-linux-uclibc-gcc", though I think the fact that it's not executable indicates that something was done incorrectly during installation.
--slacker
The permissions are as they should be. ls -altr shows the data is executable.
The Problem is not only limited to the nios2-linux-uclibe-gcc, all binaries do not work an bring the message "command not found".
The $PATH is also as it should be. Using command line completition brings the demanded bins. But still I get "command not found"-error.
I start to believe it is either a problem of the VitualBox or the distribution itself. I'm using Ubuntu 9.10.
As far as I am concerned I'm can't immagine a reason for this behaviour.
Regards.
What do "file nios2-linux-uclibc-gcc" and/or "ldd nios2-linux-uclibc-gcc" return?
Hi, I know the solution, you have to install the 32-bit libraries in order to run the bin toolchain :
sudo apt-get install ia32-libs
Cheers
