12744 Discussions
problem about Rootfs for NFS setup
Hello,sorry to trouble but I can't search any useful resource to slove my problem after trying all methods I can use in last two months.I wonder
whether anyone would give me some help or indication.
I follow the http://www.alterawiki.com/wiki/nfsfilesytem step by step. anything is ok untill start the step of Rootfs for NFS setup.
The information on my screen is
Using cable "USB-Blaster [USB-0]", device 1, instance 0x00
Pausing target processor: OK
Initializing CPU cache (if present)
OK
Downloaded 1638KB in 28.2s (58.0KB/s)
Verified OK
Starting processor at address 0x03500000
nios2-terminal: connected to hardware target using JTAG UART on cable
nios2-terminal: "USB-Blaster [USB-0]", device 1, instance 0
nios2-terminal: (Use the IDE stop button or Ctrl-C to terminate)
Uncompressing Linux...
I wonder If possible,please give me some suggestion.thank you
Lulin,
Check the Virginia Tech CCM Lab wiki page. It provides detailed information on how to install uClinux on NIOS2 in general, and Terasic DE2-70, DE4 and DE0-Nano board in particular. It also provides a step by step description on how to setup rootfs for NFS.
Tony
