problem building kernel
I am trying to build the uC linux kernel for the microtronix cyclone board. This error appears :
make: Leaving directory `/cygdrive/c/altera/kits/nios2/bin/eclipse/plugins/com.microtronix.nios2linux.kernel_0.1.5/linux-2.6.x'
ction)
make[3]: *** [drivers/ide/ide.o] Error 1
make[2]: *** [drivers/ide] Error 2
make[1]: *** [drivers] Error 2
make: *** [_all] Error 2
error: `na_ide_ide' undeclared (first use in this function)[/cygdrive/c/altera/kits/nios2/bin/eclipse/plugins/com.microtronix.nios2linux.kernel_0.1.5/linux-2.6.x/drivers/ide/ide.c] kernel_1c20_20050204 line 262
error: (Each undeclared identifier is reported only once[/cygdrive/c/altera/kits/nios2/bin/eclipse/plugins/com.microtronix.nios2linux.kernel_0.1.5/linux-2.6.x/drivers/ide/ide.c] kernel_1c20_20050204 line 262
error: `na_ide_ide_irq' undeclared (first use in this funmake: Leaving directory `/cygdrive/c/altera/kits/nios2/bin/eclipse/plugins/com.microtronix.nios2linux.kernel_0.1.5/linux-2.6.x'[/cygdrive/c/altera/kits/nios2/bin/eclipse/plugins/com.microtronix.nios2linux.kernel_0.1.5/linux-2.6.x/drivers/ide/ide.c] kernel_1c20_20050204 line 313
Can you help me?
It looks like you are trying to use a compact flash card when one is not configured/available for your target board. When configuring your kernel, disable "ATA/ATAPI/MFM/RLL support."
It works!!!! Thanks a lot dcurry and have a nice day!
