problem receiving data
Hi
I have build a small project which receives data sended by tcp. This works fine until the number of the sended packets exeeds 32. After receiving the 32nd packet the NIOS hangs.
My receiving function is
err_t port_recv(void *arg, struct tcp_pcb *pcb, struct pbuf *p, err_t err) { char *src;  err_t err2;  if(err==ERR_OK && p!=NULL)  {    src=(char *) p->payload;    tcp_recved(pcb, p->tot_len);    if(src==0x6D)      printf("%s\n",src);    else      printf("0x%x\n",src);  }  printf(">>> %d\n",p->tot_len);    err2=tcp_write(pcb,src,p->tot_len,1);  if(err2==ERR_OK)  {    tcp_ack_now(pcb);      exec_command(src);    packnumber++;    printf("# %d\n",packnumber);/*prints the number of packets*/    //send finished cmd    return ERR_OK;  }  else    return ERR_BUF;  exec_command(src);/*calls an execute function*/ }
I found my problem! I forgot to free pbuf after usage.
