problem with usb camera
I have some trouble with getting usb camera to work. I configured kernel with UsbHost following the document in http://nioswiki.jot.com//wikihome/operatingsystems/usbhost (http://nioswiki.jot.com//wikihome/operatingsystems/usbhost
In kernel menuconfig,
turn on scsi device, scsi disk
turn on host-side usb, usb dev fs, your hcd, usb device eg mass storage.
File systems -->
DOS/FAT/NT Filesystems --->
[*] MSDOS fs support
[*] VFAT (Windows-95) fs support
(437) Default codepage for FAT
(iso8859-1) Default iocharset for FAT
Native Language Support -->
(iso8859-1) Default NLS Option
[*] Codepage 437 (United States, Canada)
[*] Simplified Chinese charset(CP936,GB2312)
Besides,I configured more other thing for my usb camera
Device Drivers -->
Multimedia devices-->
<*> video For Linux
USB support-->
<*> Support for Host-side USB
[*] USB device filesystem
<*> ISP1362 HCD support
<*> USB Mass Storage support
<* > USB OV511 Camera support
then make ,make linux image ,download the zImage into DE2 board. insert the usb camera,the kernel detect the camera as follow:
Uncompressing Linux... Ok, booting the kernel.
Linux version 2.6.16-uc0 (leewood@localhost.localdomain) (gcc version 3.4.6)# 28
PREEMPT Wed Aug 2 19:39:48 CST 2006
uClinux/Nios II
Altera Nios II support © 2004 Microtronix Datacom Ltd.
setup_arch: No persistant network settings signature at 008F0000
Built 1 zonelists
Kernel command line:
PID hash table entries: 64 (order: 6, 1024 bytes)
Dentry cache hash table entries: 2048 (order: 1, 8192 bytes)
Inode-cache hash table entries: 1024 (order: 0, 4096 bytes)
Memory available: 5552k/8192k RAM, 0k/0k ROM (1608k kernel code, 938k data)
Mount-cache hash table entries: 512
NET: Registered protocol family 16
SCSI subsystem initialized
usbcore: registered new driver usbfs
usbcore: registered new driver hub
io scheduler noop registered
io scheduler deadline registered (default)
i8042.c: i8042 controller self test timeout.
Serial: JTAG UART driver $Revision: 1.4 $
ttyJ0 at MMIO 0x81004000 (irq = 1) is a jtag_uart
dmfe_probe:eth0, 50000 Khz Nios
<DM9000> eth0 I/O: 80900090, VID: 90000a46
ADDR: 00:07:ed:00:00:00
dmfe_probe:eth1, 50000 Khz Nios
Linux video capture interface: v1.00
usbmon: debugfs is not available
driver isp1362-hcd, 2005-04-04
isp1362-hcd isp1362-hcd: ISP1362 Host Controller
isp1362_hc_reset:
Clock not ready after 20ms
isp1362-hcd isp1362-hcd: new USB bus registered, assigned bus number 1
isp1362-hcd isp1362-hcd: irq 4, io mem 0x80900080
isp1362_hc_start:
isp1362-hcd isp1362-hcd: ISP1362 Memory usage:
isp1362-hcd isp1362-hcd: ISTL: 2 * 256: 512 @ $0000:$0100
isp1362-hcd isp1362-hcd: INTL: 16 * ( 64+8): 1152 @ $0200
isp1362-hcd isp1362-hcd: ATL : 32 * ( 64+8): 2304 @ $0680
isp1362-hcd isp1362-hcd: USED/FREE: 3968 128
usb usb1: configuration# 1 chosen from 1 choice
hub 1-0:1.0: USB hub found
hub 1-0:1.0: 2 ports detected
ISP1362 Host Controller, irq 4
Initializing USB Mass Storage driver...
usbcore: registered new driver usb-storage
USB Mass Storage support registered.
usbcore: registered new driver ov511
drivers/usb/media/ov511.c: v1.64 for Linux 2.5 : ov511 USB Camera Driver
NET: Registered protocol family 2
IP route cache hash table entries: 128 (order: -3, 512 bytes)
TCP established hash table entries: 512 (order: -1, 2048 bytes)
TCP bind hash table entries: 512 (order: -1, 2048 bytes)
TCP: Hash tables configured (established 512 bind 512)
TCP reno registered
TCP bic registered
NET: Registered protocol family 17
Freeing unused kernel memory: 688k freed (0x1c4000 - 0x26f000)
usb 1-2: new full speed USB device using isp1362-hcd and address 2
Shell invoked to run file: /etc/rc
Command: hostname uClinux
Command: mount -t proc proc /proc
Command: mount -t sysfs sysfs /sys
Command: mount -t usbfs none /proc/bus/usb
mount failed: No such file or directory
Command: mkdir /var/tmp
Command: mkdir /var/log
Command: mkdir /var/run
Command: mkdir /var/lock
Command: mkdir /var/empty
Command: ifconfig lo 127.0.0.1
Command: route add -net 127.0.0.0 netmask 255.0.0.0 lo
Command: ifconfig eth0 192.168.2.210
Command: route add default gw 192.168.2.1usb 1-2: configuration# 1 chosen from 1
choice
drivers/usb/media/ov511.c: USB OV511+ video device found
drivers/usb/media/ov511.c: model: Unknown
drivers/usb/media/ov511.c: Camera type (108) not recognized
drivers/usb/media/ov511.c: Please notify mark@alpha.dyndns.org of the name,
drivers/usb/media/ov511.c: manufacturer, model, and this number of your camera.
drivers/usb/media/ov511.c: Also include the output of the detection process.
Command: cat /etc/motdWelcome to
____ _ _
/ __| ||_|
_ _| | | | _ ____ _ _ _ _
| | | | | | || | _ \| | | |\ \/ /
| |_| | |__| || | | | | |_| |/
| ___\____|_||_|_| |_|\____|\_/\_/
|_|
For further information check:
http://www.uclinux.org/ (http://www.uclinux.org/
Execution Finished, Exiting
Sash command shell (version 1.1.1)
/> drivers/usb/media/ov511.c: Sensor is an OV7620
drivers/usb/media/ov511.c: Device at usb-isp1362-hcd-2 registered to minor 0
Then i ran app "vidcat" :
/> mknod /dev/video0 c 81 0
/> chmod 666 /dev/video0
/> vidcat -h
vidcat: invalid option -- h
VidCat, Version 0.7.2
Usage: vidcat <options>
-b make a raw PPM instead of an ASCII one
-d <device> video device (default: /dev/video)
-f {ppm|jpeg|png|yuv4mpeg} output format of the image
-g greayscale instead of color
-i {tv|comp1|comp2|s-video} which input channel to use
-l loop on, doesn&#39;t make sense in most cases
-n {pal|ntsc|secam} select video norm
-o <file> write output to file instead of stdout
-p c|g|y|Y videopalette to use
-q <quality> only for jpeg: quality setting (1-100, default: 80)
-s NxN define size of the output image (default: 320x240)
Example: vidcat | xsetbg stdin
/> vidcat -d /dev/video0 -p c -o test.jpg
Isochronous transfers not supported
drivers/usb/media/ov511.c: init isoc: usb_submit_urb(0) ret -28
Can&#39;t open device /dev/video0
Is the problem driver or app?
Pls help me.Thx.
--leewood
Is there nobody to use Usb camera on DE2 board?
In ISP1362 DateSheet ,it said that ISP1362 support all four type of USB transfers:control,bulk,interrupt,ISOCHRONOUS., and it also support transfer at full-speed and low-speed(not high speed). But the ISOCHRONOUS transfers are defined only for full-speed and high-speed. So it means that in ISO transfer type,we can only use full-speed.
In isp1362-hcd.c, line 1307 (function isp1362_urb_enqueue):
if (type == PIPE_ISOCHRONOUS) {  ERR("Isochronous transfers not supported\n");  return -ENOSPC;     }
So when i run test app:
#include <stdlib.h># include <stdio.h># include <sys/types.h># include <sys/stat.h># include <fcntl.h># include <unistd.h> int main() {     char devname = "/dev/video0";     printf("Begin device open test......\n");     printf("Device name: %s\n", devname);     int hf = open(devname, O_RDWR);     if(hf < 0)     {  perror("Device open test ERROR! : ");  exit(1);     }     close(hf);     printf("Device open test OK!\n");     return 0; }
The error message like this:
/>devopen Begin device open test....... Isochronous transfers not supported deriver/usb/media/ov511.c:init isoc: usb_submit_urb<0> ret -28 Device open test ERROR! : : No space left on device />
So i mask the code:
//if (type == PIPE_ISOCHRONOUS) {  //ERR("Isochronous transfers not supported\n");  //return -ENOSPC;     //}
Then the erro message like this:
/>devopen Begin device open test....... Device name: /dev/video0 start_iso_transfers:Not enough ISO buffer space for 1023 byte PTD
So I puzzled .......if ISP1362 support ISOCHRONOUS transfer, Why the error happened? Is it because the urb->dev->speed ?
Is there anyone facing the same problem? Pls give me some advice.
leewood
I met the same problem,if you have some advices,would you please tell me!!
Excuse me!
I just want to known where you get the isp1362 driver programmer?I douted that the isp1362 driver programmer which generate the problem.and i want to know which usb camera you use? ....the webeyev2000 ,v3000.
i realy want to chang a type of camera,but i don&#39;t known which camer support the chip of SE401,IBM xirlink,SN9C10x,STV680,konica webcam...
Would you please connect with me ,we can comunicate with each other.
My email: dms2002711@163.com
QQ: 524159169
to leewood:
It&#39;s because the driver we are using now doesn&#39;t support isochronous transfer,this is shown in Kconfig under C:\altera\kits\nios2_51\bin\eclipse\plugins\com.microtronix.nios2linux.kernel_1.4.0\linux-2.6.x\drivers\usb\host.
By the way,where did you get the installfile for nios2-linux ,could you tell me ?
Leewood,
sorry for late reply. I had been very busy.
I did not know isp1362 well. I am better on isp1761.
They should be similar.
You are right. It is possible to use isp1362 for isochronous transfer.
Most of the code are there.
There might be some bugs. You may look at the other chipset to find out how they work for iso.
You can find out the error from the source.
I think NPX (philips semi) have the driver. Maybe you can check with them.
Hippo
