12748 Discussions
problems with nios flash programmer
Hi.
Problems wits Nios Flash Programmer, board with nios on Cyclon II.
I have desined board with Cyclon II , sof-file generate without errors, software designed in IDE NIOS, elf-file compailed.
I configurate my sof-file by JTAG Quartus Programmer, operation complet OK.
Debugger successfully run program , trace also work.
But i have problem - Nios Flasf Programmer can not programming Epcs flash.
I have log:
-------------------------------------------------------------------------------------------------------------------------# ! /bin/sh# # This file was automatically generated by the Nios II IDE Flash Programmer.# # It will be overwritten when the flash programmer options change.#
cd C:/altera/qdesigns60/controlmodule/WORKMODULE2/software/workmod2_ver1/Release
# Creating .flash file for the FPGA configuration
$SOPC_KIT_NIOS2/bin/sof2flash --epcs --input=C:/altera/qdesigns60/controlmodule/
WORKMODULE2/workmodule2.sof --output=workmodule2.flash
Info: *******************************************************************
Info: Running Quartus II Convert_programming_file
Info: Command: quartus_cpf --no_banner --convert --device=EPCS64 --option=workmo
dule2.opt C:/altera/qdesigns60/controlmodule/WORKMODULE2/workmodule2.sof workmod
ule2.pof
Info: Quartus II Convert_programming_file was successful. 0 errors, 0 warnings
Info: Processing ended: Fri Mar 18 15:39:54 2011
Info: Elapsed time: 00:00:02
Info: Command: quartus_cpf --no_banner --convert workmodule2.pof workmodule2.rpd
Info: Processing ended: Fri Mar 18 15:39:56 2011
# Programming flash with the FPGA configuration
$SOPC_KIT_NIOS2/bin/nios2-flash-programmer --cable='USB-Blaster [USB-0]' --devic
e=1 --sidp=0x00000610 --id=1944443831 --timestamp=1300448607 --epcs --base=0x000
00800 workmodule2.flash
Using cable "USB-Blaster [USB-0]", device 1, instance 0x00
Resetting and pausing target processor: OK
Reading System ID at address 0x00000610: verified
: Checksumming existing contents
00000000 : Verifying existing contents
00010000 : Verifying existing contents
00020000 : Verifying existing contents
00000000 : Reading existing contents
00010000 : Reading existing contents
00020000 : Reading existing contents
Checksummed/read 192kB in 10.6s
00000000 ( 0%): Erasing
00010000 (33%): Erasing
00020000 (66%): Erasing
Erased 192kB in 0.0s
00000000 ( 0%): Programming
Program failed
Leaving target processor paused
# Creating .flash file for the project
$SOPC_KIT_NIOS2/bin/elf2flash --epcs --after=workmodule2.flash --input=workmod2_
ver1.elf --output=epcs_controller.flash --boot=$SOPC_KIT_NIOS2/components/altera
_nios2/boot_loader_epcs.srec
# Programming flash with the project
00800 epcs_controller.flash
Checksummed/read 64kB in 1.9s
00020000 ( 0%): Erasing
Erased 64kB in 0.1s
00020000 ( 0%): Programming
Program failed
I tried in my software write to epcs, using: alt_write_flash(fd, 0, ibuf_epcs, 256), and read , using alt_read_flash(fd, 0, obuf_epcs, 256).
Data block was writen successfully and remained in flash after power Off/On.
Next running nios flash programmer only erase Epcs.
Sometime flash programmer can finish programming, but data really not stored in Epcs, only erasing is completed.
I need Help. Have somebody any ideas?
Problem is solved by connecting on line TCK of JTAG capacitor of 10pF to GND.
