12746 Discussions
problems with timer interrupts with nios II/f
Dear all,
I've been using uclinux with an altera project using NIOSII/s cpu. In this project I've used the standard ram, timer, uart, ethernet, etc.. plus a timer called high_res_timer with 1 msec cycle time. I have used a kernel driver (inspired from one taken in a post here) and the user code has always worked well with interrupts. Making cat /proc/interrupts I have always seen the timer running. Now, changing from nios II/s to nios II/f, the interrupts don't arrive anymore. all the other things (uart, ethernet etc..) continuing to work correctly.
Any idea in the forum?
I see that probably nobody had my problem, so a second question is:
does anybody has a working uclinux project with niosII/f using a second timer?
if yes please could you post the kernel driver code (and possibly the user code)?
many thanks
I think I read, the "small" NIOS can't be used ti run Linux. But maybe I'm wrong.
-Michael
no Michael, II/s and II/f are ok with uclinux, and in fact, I have used it for more than one year for various tests. Only when I changed the CPU, in the same project, to II/f, the timer didn't produce interrupts any more.
Thanks for the response anyway.
One potential gotcha when going from NIOS II/s to /f is the addition of the data cache. Make sure that writes to the timer registers (or other hardware) bypass the data cache or you will have problems.
whether you have used irq0 for timer or not. if not ,you should change.
