12748 Discussions
pthreads rebooting uCLinux
I have a nios II 1.1 setup on the nios dev kit which seems to work well: JTAG console, telnet, ftp and http are OK and debugging applications works.
But when I try to create a pthread (I tried the ex1 sample) then the nios system reboots.
Am I missing something ?
(the ex1.c sample code is below)
Marc
# include <stddef.h># include <stdio.h># include <unistd.h># include "pthread.h"
void * process(void * arg)
int i;
fprintf(stderr, "Starting process %s\n", (char *) arg);
for (i = 0; i < 10000; i++) {
write(1, (char *) arg, 1);
return NULL;
int main(void)
int retcode;
pthread_t th_a, th_b;
void * retval;
retcode = pthread_create(&th_a, NULL, process, (void *) "a");
if (retcode != 0) fprintf(stderr, "create a failed %d\n", retcode);
else fprintf(stderr, "create a succeeded %d\n", retcode);
retcode = pthread_create(&th_b, NULL, process, (void *) "b");
if (retcode != 0) fprintf(stderr, "create b failed %d\n", retcode);
else fprintf(stderr, "create b succeeded %d\n", retcode);
retcode = pthread_join(th_a, &retval);
if (retcode != 0) fprintf(stderr, "join a failed %d\n", retcode);
else fprintf(stderr, "join a succeeded %d\n", retcode);
retcode = pthread_join(th_b, &retval);
if (retcode != 0) fprintf(stderr, "join b failed %d\n", retcode);
else fprintf(stderr, "join b succeeded %d\n", retcode);
return 0;
OK forget it. I just re-compiled and re-linked all and it&#39;s OK now. http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/smile.gif
Marc
I have exactly the same problem (rebooting when launching a threaded app), the only difference is that re-compiling doesn&#39;t fix anything http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/mad.gif ...
Any idea of what can be wrong ? I guess it is while compiling, but I can&#39;t get what i missed.
Thanks a lot.
Max.
PS : I&#39;ve tested with the code in the first post.
