12748 Discussions
pushbutton interrup for ALTERA cyclonIII development board
pushbutton interrupts don´t work
My Quartus project is a download from http://www.nioswiki.com/exampledesigns/nio...20designexample (http://www.nioswiki.com/exampledesigns/niosii3c120designexample)
20090508a nios2 linux 3c120 125mhz.tar.gz was unpacked (I am not running linux though but uC-OSII with tools on Windows XP)
My ALTERA Cyclone III Development Board be seen at http://www.altera.com/products/devkits/altera/kit-cyc3.html (http://www.altera.com/products/devkits/altera/kit-cyc3.html
I previously worked on the NEEK board and had the button interrupt working fine there for that board. I ported the code to My new project running on the Cyclone III Development Board and looked up the corresponding definitions in system.h
My code now looks like this :
#define  BSP_BUTTON_ADDR        USER_PB_PIO_4IN_BASE volatile INT32S      edge_capture;      /* A variable to hold the value of the button pio edge capture register. */ void BSP_HandleButtonInterrupts(void* context, INT32U ID) {     volatile int* edge_capture_ptr = (volatile int*) context;     // Store the value in the Button's edge capture register in *context.     *edge_capture_ptr = IORD_ALTERA_AVALON_PIO_EDGE_CAP(BSP_BUTTON_ADDR);          switch(edge_capture) {            case 0x01:                registerPushButton(PUSHBUTTON_LEFT);                break;                       case 0x02:                registerPushButton(PUSHBUTTON_RIGHT);                break;                           case 0x04:                 registerPushButton(PUSHBUTTON_UP);                break;                           case 0x08:                 registerPushButton(PUSHBUTTON_DOWN);                break;                           default:               break;     }     // Reset the Button's edge capture register.     IOWR_ALTERA_AVALON_PIO_EDGE_CAP(BSP_BUTTON_ADDR, 0); } void BSP_InitPushButtons(void) {     // Recast the edge_capture pointer to match the alt_irq_register() function     // prototype.     void* edge_capture_ptr = (void*) &edge_capture;     // Enable all 4 button interrupts.     IOWR_ALTERA_AVALON_PIO_IRQ_MASK(BSP_BUTTON_ADDR, 0xf);     // Reset the edge capture register.     IOWR_ALTERA_AVALON_PIO_EDGE_CAP(BSP_BUTTON_ADDR, 0x0);     // Register the interrupt handler.     alt_irq_register(USER_PB_PIO_4IN_IRQ, edge_capture_ptr, BSP_HandleButtonInterrupts ); }
When I run the code It seems I get BSP_HandleButtonInterrupts() called continuously making the rest of the code freeze.
When I step into BSP_HandleButtonInterrupts() , *edge_capture_ptr gets the value of 15.
Any suggestions ???
Best regards
fixed
Changed the content of Input Options for user_pb_pio_4in in SOPC builder to ...
Synchronous capture [checked]
Rising edge [selected]
Generate IRQ [checked]
Edge [selected]
No other options was marked
Made a complete rebuild of SOPC builder and Quartus
New rebuild with create-this-app / create-this-bsp
New import into Nios II IDE
