Hello.
I get the following errors in Eclipse when trying to debug my Nios2 program: :2342: Connection refused. A little more info: I am running Quartus & Nios2eds v9.1 In the Debugger tab in the Debug Configurations dialog in Eclipse, I have the “Altera CDI GDB Debugger” selected. Is this correct? I am using a Cyclone EP1C20 dev board. I am connected to the dev board with a ByteBlaster2 . I am able to successfully build and load my FPGA design into the FPGA via Quartus. I am running an OpenCore2 time-limited Nios2 core. Any help in figuring out what I’m doing wrong would be greatly appreciated. Thank you Scott WildLink Copied
I found it... If I click on the debug pane in Eclipse before starting the debugger, it works.
