Ankündigungen
12748 Diskussionen
regarding data transfer between two custom components or peripherals
Geehrter Beitragender II
1.259Aufrufe
I created register as the custom component and instantiated it twice.In a sopc system,now i have 2 separate registers,nios-ii processor,on-chip memory and also one DMA controller.I want to know,how to make data transfer between these two registers using a DMA controller.how and where,i want to mention the address for read and write from DMA.
help me
3 Antworten
459Aufrufe
You can see sopc generates two different base address for two different register.Using base address you can differentiate and communicate with two registers.For write operation you can use function.IOWR(BASE_ADDRESS,OFFSET,VALUE) and for read operation you can use function IORD(BASE_ADDRESS,OFFSET)
459Aufrufe
--- Quote Start ---
--- Quote End ---
actually i really want to make data from one component gets transferred to another sir
459Aufrufe
--- Quote Start ---
--- Quote End ---
You can assign address of one of your custom component as a read address of DMA and assign address of other custom component as a write address of DMA.You can find HAL driver of DMA in the user guide of DMA.
Antworten
