rgd serial port as std i/o
Hi
i would like to clarify myself
regarding the following.
in two processor system
if i attach serial port as std i/o tothe first
processor(as per alphabetical order) and the other
processor to jtag uart, if i run it is doing this
by printing on the console as
"can't open uart : permission denied"
and then it stops
what could be the reason?
also i observe that it launches in the alphabetical order.
please do comment on this.
regards
prasad
Does it works if you remove the second CPU attached to JTAG uart?
it seems more a problem of the configuration of the peripherals on the first core...
Paolo
Hi paolo
actually i have attached only one processor to the jtag uart and the other
to the serial port. exclusively
can u tell the reason.
i am unable to get it.
regards
prasad
What I was saying is that the problem you have seems to me not relative to the fact you are using 2 CPUs.
Does the same problem happens when your design has just 1 CPU?
Paolo
