safe mode program
I wish to have a safe mode boot
this means that usually the program that is found on the flash will be loaded and run
but if something happen and the application hang I wish to press a button and the Nios will
moved to execute some safe mode program(like downloading a new software) how can I do it?
I also wish that the safe mode program won't be a part of the program that is usually run from the flash (i wish to download them to the HW in to different occasions).
I can't place the configuration(.sof) on the flash (I can do it only on the epcs). and so I can't do the same thing as altera did with the evaluation board
I was thinking of some kind of interrupt that will be called on a button press
but the problem how do I separate it from the main program , where can I store it and how can I make it run in parallel
to the main program
So, your custom board has no flash or no config-controller(such as CPLD)? I implement such idea like the Altera NDK.
hi
you can program the flash with your own factory configuration(overwriting the default one that comes with the dev board) using the nios-flash-programmer . then you can search for and transfer control to a new application image using the remote update block
regards
